Like Tree2Likes
Tamiya TRF418
Old 01-08-2018 | 02:15 PM
  #2146
Nortran11's Avatar
Loving this car. At the half way mark of the season I am leading my class by 11 points, haven't finished lower than 3rd and been on the top step twice.
The odd thing is....the box setup is on fire....can't be touched. The minute I start tweaking a bit and make adjustments....I am all over the place and a second slower.
Nortran11 is offline
Old 10-04-2018 | 09:36 PM
  #2147
Will the Robinson Racing "PRO" Machined Spur Gear fit the 418? (Sorry, I'm not allowed to post the URL) What other brands are compatible?
Thanks,
alwin is offline
Old 10-05-2018 | 05:42 AM
  #2148
sosidge's Avatar
The holes look like they are in the right place, but the 418 likes a "thin" spur, and I don't know how thin the RRP spur is.
Panaracer fit for sure. There are probably others referenced in the thread.
sosidge is offline
Old 10-05-2018 | 10:04 AM
  #2149
Thanks for that - Panaracer spurs are available in my area.
alwin is offline
Old 10-15-2018 | 09:26 AM
  #2150
jdawg81's Avatar
I raced my TRF418 recently which is still quite competitive as I was able to get into the A-main with it. I noticed that when the wheel turns left as shown in the attached image below, the inside of the wheel touches the edge of the suspension arm. It does this for both the left and right side. I'm going to assume that it's always been like this and I just didn't notice it until now. I don't think it's supposed to be like this and I'm pretty sure I did not assembly it wrong either. Has anyone else had this issue?
jdawg81 is offline
Old 10-15-2018 | 09:44 AM
  #2151
OVA's Avatar
OVA
Hi Jason
I t could be the wheel rim is very soft can flex....check your front C hub or spacer or king pin bushing is thicker at the top to help the clearance issued
OVA is offline
Old 10-15-2018 | 05:39 PM
  #2152
Dan's Avatar
Dan
I'm selling a barely used Samix conversion if anyone is interested. $40 shipped
Dan is offline
Old 10-15-2018 | 10:13 PM
  #2153
jdawg81's Avatar
Originally Posted by OVA
Hi Jason
Hey Franko, you got me thinking when you said check the C hub. I installed Exotek aluminum C hubs because the Tamiya ones always broke with the slightest tap on the wall. I switched back to the Tamiya hubs the wheels no longer touches the suspension arm when the wheels are turned left or right.
jdawg81 is offline
Old 10-16-2018 | 01:31 PM
  #2154
The exotek hubs would have been bent. They don’t shatter but they will bend on a hard collision.
Qatmix is offline
Old 10-17-2018 | 06:09 PM
  #2155
File the arms to get some clearance. It's being done even with the newest/latest kits
rccartips is offline
Old 10-20-2018 | 03:37 PM
  #2156
jdawg81's Avatar
Ok it looks like this is normal if filing is required to get more clearance. I will file the arm down a bit and l put the exotek hubs back on then as they don't look bent after inspecting them.
jdawg81 is offline
Old 10-21-2018 | 07:37 AM
  #2157
fat500's Avatar
Looking at that pic I will say your c hubs are bent.
fat500 is offline
Old 10-22-2018 | 09:15 AM
  #2158
jdawg81's Avatar
I compared both C hubs side by side and they don't appear to be bent. I would imagine that if they were bent due to a hard crash that one hub would be more bent than the other. But they both look identical and both sides have the same amount of clearance between the arm and wheel.
jdawg81 is offline
Old 10-23-2018 | 12:56 AM
  #2159
Electr0n's Avatar
@jdawg81 Which suspensions blocks are you running at the front ?
Electr0n is offline
Old 10-23-2018 | 07:09 AM
  #2160
jdawg81's Avatar
I'm using the what was included in the kit so it should be 1C suspension mount blocks.
jdawg81 is offline
