airplane system on a car. >
Old 07-20-2013 | 03:42 AM
Default airplane system on a car.
Hello,
I want to add more channels to my crawler and ran into a budget problem.
a 4ch system is 300+ dollars.
I saw a plane 6 ch system that was about 50 dollars.
what problems will I run into when trying to fit this system to my crawler?
is there someway around those problems?
thanks,
Guy.
Dice2Jr is offline
Old 07-20-2013 | 04:16 AM
howardcano's Avatar
Make sure it's on 2.4GHz. The 72MHz band, by law, is for airplanes only.
howardcano is offline
Old 07-20-2013 | 11:15 AM
If I'm not mistaken the throttle is typically different, no to little brakes-reverse with neutral all the way down instead of nearer center travel, holds position instead of springing to neutral. The different neutral can be an issue for calibrating to the ESC. Believe I've seen conversions discussed on some of the airplane sites.
Dave H is offline
Old 07-20-2013 | 01:40 PM
The for your replys.
I'm sure it's 2.4.
The transmitter has 2 sticks. Each With a y and x axis. One springs back to the middle and One does not.
I planned to make the springy One for throttle/reverse and front steering. The non springy One is for rear steering and a winch. One of the two switches will be for lights and that leave me With one spare channel.
Do you guys see any problems that i shall encounter With this plan?
Im New to the rc hobby, So im Sorry if my question are a bit dumb.
Thx,
Guy.
Dice2Jr is offline
Old 07-20-2013 | 01:46 PM
stick radios have been used before for crawlers. i myself run my ax10 based crawler on a spektrum dx6i. right stick is throttle and front steering, left stick is rear steering, and i have 2 switches set up for the dig, one switch puts the back axle in neutral, the other locks the rear axle.
Sharkey_t is offline
Old 07-20-2013 | 02:14 PM
did you have to make any modifications in order for the system to work?
transmitter\reciever\esc\battery,anything?
or did it just plun-n-play?
thx,
Guy
Dice2Jr is offline
Old 07-20-2013 | 11:03 PM
its plug and play.
Old 07-21-2013 | 06:21 PM
Aren't airplane escs designed with the idea that lots and lots of cooling airflow is always passing around the esc? You might want to hook up a fan. I suppose thay are also designed with the idea that they will be constantly at 1/2 throttle or above, so maybe a fan won't be necessary. Probably a good idea to check temps occassionally.
Rufus2010 is offline
Old 07-21-2013 | 06:50 PM
meno1103's Avatar
using an airplane esc for a surface vehicle is a whole different story (mainly with brakes), but I think the intentions here are to use an airplane radio with the rest of the normal crawler gear.
meno1103 is offline
Old 07-21-2013 | 06:58 PM
Yeah, I think you are right.
Old 07-21-2013 | 07:41 PM
Devigili22's Avatar
Just read the title hmm?
Devigili22 is offline
Old 07-21-2013 | 08:22 PM
Eh, the thread title isn't all that clear. Although I agree the post is more so best I can tell.
Dave H is offline
Old 07-21-2013 | 08:26 PM
I'm sure it's 2.4.
Thx,
Guy.
Duh, I didn't think of using the channels differently.
I'm not a crawler guy but I could see the rear steer being held wherever perhaps being an advantage at least in some situations?
Dave H is offline
Old 11-01-2017 | 08:06 AM
If your OK with opening up your transmitter (will probably void any warranty) You could see if you can attach a small spring to the opposite side of the throttle gimbal. That way it would return to center (both springs will have to be the same tenshion) when you release the gimbal.
Rockyroad1 is offline
