INTECH RACING - BR-6 BUGGY!!! >
Old 07-04-2013 | 02:11 AM
  #1306
Originally Posted by Orcine Abreu
Hi!
I´ve been workking on the Intech Br6 and make some changes on this car.
I notest that we got little of Downtravel on the front of the car. Just because the front Tower are too hight and the shock are shorter. So we got no downtravel using this shock.
Some Outdoor thack got a lot of bumps and rolls on the thack, so we need lot of downtravel to make if works better, and we have to get lots of Total Carter too, to meke the car reacts more consistence.
I resolve this issue using that:
1) Thake the older Intech BR5 Rear shocks and put it on the front of the Intech BR6. This makes the car get lots of downtravel and works perfectly. The other resolution option are uses the older Intech BR5 Tower, because they are shorter then the new Intech BR6 one.
2) The Intech BR6 got max total caster 25.5º, using the aluminium Caster Block. So I replace the CNC FRONT SUSPENSION ARM HOLODER 7075-T6 (FF) to CNC FRONT ANTI-DIVE PLATE (FR). I drimled on the botton of the pice ust to put the bumper. This way I got lot of Total Caster. So I can compessate the turning ability using TOE.
The second modification I will test on Friday. So a let you know about that. It´s realy important to Intech doing those modification, because the car reacts better.
We are prepared for THE DIRT RIO in this weekend. I will make some photos and send it to you.
Drivers like Adan Drake, Kriss Moore, Adrian Castro, and The Brasilian Nats Champ Henrique Winnik, will be on this great track buided by Joey "The Dirt" and Aron. It will be the biggest challenge for this year.
We are represent Intech with to Drivers, Orcine Abreu and Ulisses Silva.
You can also use xray 16 degres castorblock.
I use them on both my electric and nitro buggies and it work very well on bumpy tracks.
gustavsen is offline
Old 07-04-2013 | 03:25 AM
  #1307
tony montana's Avatar
I use the blue ofna truggy starter box
tony montana is offline
Old 07-04-2013 | 01:21 PM
  #1308
Originally Posted by Chester623
Guys can you give me suggestions on the best starter box for the BR-6 I need a new one as I'm jumping over from a losi and the losistarterbox will not work!! Thanks
I use the Losi. But, I modified it to have a slider on it for both my buggy and truggy.
Ben Burtle is offline
Old 07-06-2013 | 06:07 PM
  #1309
VPProUSA's Avatar
The INTECH ER-12 is almost ready!
VPProUSA is offline
Old 07-06-2013 | 10:41 PM
  #1310
rcmania74's Avatar
Any Idea On Street Price Yet? I Want One
rcmania74 is offline
Old 07-07-2013 | 05:52 AM
  #1311
VPProUSA's Avatar
Not yet.
VPProUSA is offline
Old 07-07-2013 | 06:29 PM
  #1312
rcmania74's Avatar
Are there Different Colored Shock Collars Available For The Br6 Purple Or Green Or Something
Old 07-07-2013 | 07:02 PM
  #1313
VPProUSA's Avatar
No there is not.
VPProUSA is offline
Old 07-08-2013 | 01:36 AM
  #1314
IRSR's Avatar
Thumbs up INTECH take 2nd and 3rd positions!
This weekend, INTECH Denmark and Sweden drivers attended the race in SMRC.
Left: Rune Gustavsen from Denmark- Mini Bizz Racing
Middle: Hans Hurtig from Sweden- Kullagergrossisten
Right: Andreas Klausen from Denmark- Mini Bizz Racing
Rune took the 2nd again with the BR-6, and Andreas followed placing 3rd in the race! Congratulations!
1st Jan D Hansen
2nd Rune Gustavsen- INTECH BR-6
3rd Andreas Klausen- INTECH BR-6
INTECH
IRSR is offline
Old 07-08-2013 | 09:33 PM
  #1315
rcmania74's Avatar
Im Stoked! Picking Up My Car At The Ups Office At 7:30 Am And HopIn I Can Get It Together In Time To Run Tomorrow Evening
Old 07-08-2013 | 09:36 PM
  #1316
Good luck with the build! That would be super fast!
masher81 is offline
Old 07-09-2013 | 09:18 PM
  #1317
rcmania74's Avatar
Got A Buddy To Come Help Do Some Wrenching And Got The Car Together In Time ...Too Bsd Not Enough. People Showed Up To Race... I Like The Car ... I Find It Comparable To My Mbx7... Had A Couple Little Issues But Nothing Major... Has Great Potential
Old 07-09-2013 | 10:43 PM
  #1318
Did you stick with the box setup?
masher81 is offline
Old 07-10-2013 | 09:41 AM
  #1319
rcmania74's Avatar
Didnt Really See A "BOx" Set Up... I Put My Mbx7 Set Up On It Or Alot Of It... Its Pretty Good... I Have Some Bind In The Front To Figure Out And I Got The Mugen Linkage Set Up For It Because The Rods Pull Out Of The Plastic
Old 07-10-2013 | 09:52 AM
  #1320
VPProUSA's Avatar
The front end bind is normal for this style of C-hub (Losi style). If you run the lowest inner hole for the camber link, it smooths it out some.
My 8ight 2.0 and my Agama A8 both felt the same in the front.
VPProUSA is offline
