Aircraft vs. Surface Servos?
#16
It depends on the servo. Low profile aileron servos are designed to be mounted out in the wings and thus will often have really long leads on them.
Servos are designed for different characteristics depending on intended use. A standard aircraft servo doesn't need to very strong, quick or durable so they tend to be cheap and weak. Use only in light duty applications. Heli servos are usually designed for extreme precision. Servos for nitro car servos are (or at least should be) designed for abuse. They need to be strong (hence metal gears), fast, vibration resistant and high torque. That's why they are usually more expensive than an aircraft servo with similar specs.
#17
Don't think I would argue with some of the big heli guys though, that might be some of the toughest and most critical uses. Those things are wild when the good pilots start tossing them around.
#18
Yeah, it's funny. Hang out on some of the airplane forums and they will say the exact opposite, cars don't need strong quick or durable servos.
#20
....sadly too many are snobbish because they crap $100 bills though.
