The Speed Passion Thread >
Like Tree57Likes
Old 04-25-2013 | 05:24 PM
  #11506
YoDog's Avatar
Originally Posted by Newbster98
Can any one give me any idea what a safe operating temp would be for a Reventon stock club race esc and 17.5 competition V3 motor? I have been running a consistent 120 to 125 degrees f. What is your opinion on the temp? Any input would be greatly appreciated.
If you are happy with the performance... it's perfect!
You could probably go up a tooth on your pinion as 130-140 is very safe.
YoDog is offline
Old 04-26-2013 | 11:10 AM
  #11507
Any one know when the 13.5 firm ware is coming??
What settings are people using for the reventon using a tp13.5 green rotor.
On the lcd box it has
Hb power ??
Slope rate??
Dont see these on any sheets??
Quietman is offline
Old 04-26-2013 | 02:11 PM
  #11508
Robertcooper88's Avatar
Hb power ??
Slope rate??
What do you mean 13.5 firmware? Are you running boosted or Blinky?
Robertcooper88 is offline
Old 04-26-2013 | 02:59 PM
  #11509
13.5 boosted
On speed passion web and in instructions of reventon says stock software soon???
Quietman is offline
Old 04-26-2013 | 03:16 PM
  #11510
13.5 boosted
Stock1 is the software that you want to use...
And I see there are at least 2 setup sheets for 13.5 boost setting....look at the below link and click 1/10th touring stock class
http://www.speedpassion.net/us/escsetup.asp
Solara is offline
Old 04-26-2013 | 04:41 PM
  #11511
Ok
But on the instructions for the hybrid boost software description it does say this is for motors up to 10.5 software for higher turn motors available soon
But will give these another go
Quietman is offline
Old 04-26-2013 | 05:48 PM
  #11512
YoDog's Avatar
Ok
I think you may be confusing the Hybrid firmware with the more common and current V20 release.
Controller version V1.1.0.22 is what is shown as the latest release on the website. From January 2013.
Use Stock1 for your speedo and you should be good to go.
YoDog is offline
Old 04-27-2013 | 05:19 PM
  #11513
hey guys i need some help please i upgraded my reventon pro,calaborated it and drove for less than a minute then it shuts down now it's not staying on when i push the button but if i hold it down the sevo gets power but not the motor can anyone help me.
spike8625 is offline
Old 04-28-2013 | 07:07 PM
  #11514
EDWARD2003's Avatar
I just wanted to let you know the Speed Passion MMM motor series and Reventon S speed controls are a wicked setup for F1 racing. Over the weekend I managed to lay down the fastest laps against other competitors who were using expensive speed controls/motor setups. The power transfer from the MMM motor to the wheels was consistent and smooth, as many of you know these are important elements for F1 racing. If your looking for smooth acceleration coming out through the corners and mad rip down the straight stretches you cant beat SP MMM motors and SP speed controls. Regardless of what Speed Passion speed control and MMM motor you get, you know its going to be the best.
Thanks SP!
EDWARD2003 is offline
Old 04-29-2013 | 09:16 AM
  #11515
hi guys, i just got my hands on the reventon r and been testing it on the track but getting some problem with it. Currently the esc is running on stock1 v19.
Problem is the esc will suddenly run without boost in a middle of a run. i have to do a full stop or sometimes turn off and on the esc to get the boost to working again.
i also get 2 lights blinking on the esc after the run.
Hope the experts can help.
Eazy is offline
Old 04-29-2013 | 02:05 PM
  #11516
hi are you running lipo cut off or overheat protection, check next time it happens if the esc and motor are cool or not close to over heating also that the lipos are above 7.9volt turn them both off its the only bug with the esc and also download the new pc software as you should be running stock1 v20
hope it helps
tcboy1983 is offline
Old 04-29-2013 | 06:32 PM
  #11517
hope it helps
Hi thanks for the reply,
I turn off both overheat protection and voltage cut off when I tested.
Motor n esc came of 50degC when temp immediately after the run.
Is there another update for the reventon R? Cause last I check it was only v19 stock1 the rest of the profile was able to update to v20
Thanks again
Eazy is offline
Old 04-29-2013 | 08:27 PM
  #11518
2 lights blinking is mean the sensor wire connection have some problem. Therefore, the ESC will no boost. Maybe the sensor wire has a bad contact. Change the other sensor wire and then try again.
WMGary is offline
Old 04-29-2013 | 08:29 PM
  #11519
Could you update the ESC firmware again?
WMGary is offline
Old 04-29-2013 | 10:13 PM
  #11520
I did swap to a new sensor wire but it did not help. The thing is this problem is intermittent, it starts fine then in the middle of a run i don't get the boost anymore as though it went to blinky I have to go to a full stop or even on n off again then it works again.
Eazy is offline
