Like Tree70Likes
TT-01 Forum
Old 04-05-2013 | 05:26 AM
  #2221
TonyD.'s Avatar
is there a bigger pinion that you can run other then a 22t with the stock spur gear and stock motor mount?
TonyD. is offline
Old 04-05-2013 | 05:29 AM
  #2222
Which Spur is stock? My TT-01E Type R came with three.
Most at our track run the 28 tooth pinion with the 55 spur. The 29 is too large.
.crispy is offline
Old 04-05-2013 | 10:35 AM
  #2223
TonyD.'s Avatar
61t spur
TonyD. is offline
Old 04-05-2013 | 11:36 AM
  #2224
Smile Can i have a cheap tamiya R/C car?
hi. do you know any places that have cheap tamiya rc cars? (in malaysia, selangor) "i dont know how to post threads so i decided to post here" sorry 4 disturbing though.
SuperKiddy is offline
Old 04-05-2013 | 12:14 PM
  #2225
silverbmr's Avatar
whats the difference between using a 55 spur / 25T vs 58 spur / 25T set up ?
silverbmr is offline
Old 04-05-2013 | 12:43 PM
  #2226
kwkride's Avatar
55t / 25t = 5.72 FDR
58t / 25t = 6.03 FDR
kwkride is offline
Old 04-05-2013 | 01:11 PM
  #2227
godofcable's Avatar
the 55T spur will give you a slightly higher top speed
godofcable is offline
Old 04-05-2013 | 02:28 PM
  #2228
Originally Posted by godofcable
the 55T spur will give you a slightly higher tops speed
And less acceleration.
A smaller spur = more top speed
A bigger spur = more acceleration.
addicted2blue is offline
Old 04-05-2013 | 02:29 PM
  #2229
silverbmr's Avatar
thanks for the responses
Old 04-05-2013 | 02:33 PM
  #2230
Originally Posted by MD
If you go to the Tower listing of the car on the page you sited, it's 190MM.
http://www3.towerhobbies.com/cgi-bin...&I=LXCVNP&P=OW
The wheelbase is 257mm, the 190mm you've mention is the width of the body.
190mm wheelbase would be even smaller then a mini (that's 210mm)
Old 04-06-2013 | 05:05 AM
  #2231
TonyD.'s Avatar
Only thing I need now is the motor. I can't wait to get some track time with it before the tcs race.
TonyD. is offline
Old 04-06-2013 | 07:02 AM
  #2232
Nice car TonyD.
Been lurking the forum for 3 months now and finally decided to join.
I am learning one step at a time and so far I am hooooooked
I bought two which should arrive Monday A TT01 and a TT01D.
The TT01 has a
TT01E Kit with Front Motor Conversion
-Lundsford Titanium Turnbuckles
-RPM Ball Cups
-Upgraded front CVD's
-Upgraded Propeller Shaft
-Active Hobby Countersteer Diff kit
-Ball Bearings throughout
-Tamiya Disk Brake/Intercooler accessories kit
The TT01D is stock.
I don't know too much about the hopups on the first one but I was hoping you guys could shed some light.
Should I remove any of the mods? perhaps overkill for a noob?
Thanks and I hope to stick around for a long time
Vroomin is offline
Old 04-06-2013 | 07:09 AM
  #2233
TonyD.'s Avatar
Originally Posted by Vroomin
Nice car TonyD.
The TT01 has a
-RPM Ball Cups
The TT01D is stock.
I'm still new to the world of the TT-01 I'm learning as I go. Hope you enjoy your cars. Hope to run mine very soon.
TonyD. is offline
Old 04-06-2013 | 07:11 AM
  #2234
TonyD.'s Avatar
Nice car TonyD.
The TT01 has a
-RPM Ball Cups
The TT01D is stock.
I would also do the shock upgrade. It will make the car handle way better.
TonyD. is offline
Old 04-06-2013 | 10:49 AM
  #2235
Thanks Tony I appreciate it. I think I will move the shocks and motor over from the Dspec over to the Espec since it already has more hop ups.
Hopefully others can chime in as well.
Vroomin is offline
