Like Tree246Likes
Xray XB4 thread
Old 04-01-2013, 08:31 PM
  #2011
RShockley's Avatar
Originally Posted by Thereallion
Yeah, I've heard good things about both... I'm going to order one of the two tonight... Just not sure... Leaning towards the Orion...
I have had a good experience with all my Orion electronics. I'm tuning the r10 pro and the 6.5t Orion motor. Both are good options. The Orion was easier for me to get setup the way I like it though.
RShockley is offline
Old 04-01-2013, 08:46 PM
  #2012
B00t13g's Avatar
I'm running an r10 pro and a reedy mach 2 6.5 and couldn't be any happier with the combo.
B00t13g is offline
Old 04-02-2013, 01:20 PM
  #2013
Default anti roll bars
Hey,
could some one tell me how many default antiroll bars are included in kit?
In XB4 part list i found 1 , 1.2
but in manual there is a 1 in front susp. 1 in rear so manual suggest there is a 2 antiroll bars 1.2.
farm is offline
Old 04-02-2013, 01:28 PM
  #2014
The Kit came with 2 - 1.2 roll bars and they are the same for front and rear. They are available as options in 1.0, 1.1, 1.2, 1.3, 1.4. 1.6, 1.8.
sgrpgh is offline
Old 04-02-2013, 01:44 PM
  #2015
Thanks,
soo kit contains:
303431-K ALU 4.9MM BALL END - BLACK (4)
303454 BALL JOINT 4.9MM - OPEN (8)
362472 ANTI-ROLL BAR 1.2 MM - 2
farm is offline
Old 04-02-2013, 03:49 PM
  #2016
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
Subscribed
ozzy-crawl is offline
Old 04-02-2013, 09:43 PM
  #2017
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by farm
Thanks,
soo kit contains:
yes
Odin544 is offline
Old 04-03-2013, 03:52 AM
  #2018
What shims/oring are you using guys.
Metal /plastic /rubber ?
farm is offline
Old 04-03-2013, 04:35 AM
  #2019
neallewis's Avatar
My Ralls Racing XB4 shock towers have arrived today:
Can't wait to get them fitted and tested this weekend. Hopefully they will sort out the back end problem I'm having.
They are from Ralls Racing in the UK. http://www.rallsracing.com/ [email protected]
"Made from 4mm black grp and extensively developed and tested by the shop team. They offer added strength without extra load on the bulkhead due to the flex nature of grp, and an extra row of camberlink holes
We have found the extra camberlink holes have helped to nail the back end of the car down stopping the over rotation, squaring the car up quicker and allowing us to get on the power earlier out of a turn"
neallewis is offline
Old 04-03-2013, 04:41 AM
  #2020
neallewis's Avatar
Attachment 1051705
I'm using these: http://www.maplin.co.uk/silicon-washers-99272
Two on each shock shaft bottom. They are nice cushiony bump stops, and work well for me.
Old 04-03-2013, 04:47 AM
  #2021
neallewis's Avatar
Also just fitted:
Yaiba Racing XB4 Woven Graphite Long Upper Deck V.2 - YRG070
It's available from MB Models: http://www.rccarshop.co.uk/index.php...r-deck-v2.html
Old 04-03-2013, 05:11 AM
  #2022
blade954's Avatar
Trader Rating: 23 (100%+)
Originally Posted by asc6000
eeyyaa,,,, nnnoooo thanks
I think with the right Paint job will look better... i'm going to have a look at them.
blade954 is offline
Old 04-03-2013, 05:16 AM
  #2023
ozzy-crawl's Avatar
Have been searching with no luck,can anyone tell me what the largest pinion is that will fit the stock spur and if any other brand spurs fit.
I will be running stock and were i run thats 17.5t
Any help much appreciated
Old 04-03-2013, 05:26 AM
  #2024
H0LESH0T's Avatar
Originally Posted by neallewis
Also just fitted:
Very nice, nice work on the wiring
H0LESH0T is offline
Old 04-03-2013, 07:27 AM
  #2025
neallewis's Avatar
Thank you! I'll re-do it at some point, but its working fine now as it is. I want to get the motor wires underneath the topdeck.
