Like Tree21Likes
New LRP Flow Esc
Old 03-22-2013 | 10:02 AM
  #421
spencehotbodies's Avatar
Originally Posted by 008-Racer
I have run both with 17.5 & 13.5 and couldn't tell the difference
I think you would feel the diffrence in mod.
spencehotbodies is offline
Old 03-22-2013 | 11:14 AM
  #422
superspeed's Avatar
I want to know the LRP support experience and availability. A while ago, LRP used to be distributed via Global and Ace, their support was hardly none. I remember there was sticker on the box that said mail the ESC to Germany; hobby shop had a handful of LRP ESCs that couldn't be services or returned...
superspeed is offline
Old 03-22-2013 | 11:23 AM
  #423
RedBullFiXX's Avatar
Team Associated are the official LRP support group in USA
I've had two updates for FREE, over the last few years
So support is not a problem
Not always the fastest I've heard, but they've been great for me
RedBullFiXX is offline
Old 03-22-2013 | 12:48 PM
  #424
IgorR's Avatar
Originally Posted by JustWill75
I can't get my usb bridge to work with my Laptop running window 8. Can anyone give me some help?
Hello,
I have the same problem on my windows 8 computer.
About the USB Bridge driver installation. I found that it is not installing because the drivers is not digitally signed with a certificate.
This link explain you how to do to install it :
http://www.craftedge.com/tutorials/d...tall_win8.html
About the LRP Win-Version v2.0.7. I still not able to make it run under windows 8. I've tried with the different compatibility's modes (Windows XP, Windows 7). It always crash after launching.
I've post the question on LRP forum few month ago and so far I did not get any answer.
IgorR is offline
Old 03-22-2013 | 03:22 PM
  #425
Matt Trimmings's Avatar
Ive got a blinky question for you guys...Is there a significant difference between the stock (1.4) software and the new Stock (5.0) software if you are only running blinky. It seems to primarily change the agressiveness of the boost profiles but if you dont even get into that does it even matter? I mainly run blinky stock and am trying to justify getting the spec 2 usb adapter. Thanks!
Matt Trimmings is offline
Old 03-22-2013 | 04:09 PM
  #426
JustWill75's Avatar
I like that question....
JustWill75 is offline
Old 03-22-2013 | 04:14 PM
  #427
JustWill75's Avatar
Originally Posted by IgorR
Hello,
I knew I wasn't going crazy. So does anyone with windows 8 and a Flow been able to use there USB bridge?
Old 03-22-2013 | 05:06 PM
  #428
jag88's Avatar
not me ...
jag88 is offline
Old 03-22-2013 | 06:37 PM
  #429
I just bought a Flow and I have a general question about 1s use. I am using it with a 12 scale car and a Novak Ballistic 13.5. I hooked it up and bench tested it in the car and it seems like the motor feels fairly slow on my bench compared to the motors I run with 7.4V. Is this typical for 1s 3.7V operation?
rossb is offline
Old 03-22-2013 | 06:41 PM
  #430
Yes
You have half the voltage
Power to weight ratio is nearly double to a TC as well
What size and surface track do you plan to run with your 13.5 Flow ?
Old 03-22-2013 | 06:55 PM
  #431
geeunit1014's Avatar
No difference for blinky. Only fine tuning of boost like you said. If your club is serious about checking things, right now only the 1.4 firmware is roar approved for blinky..
geeunit1014 is offline
Old 03-22-2013 | 07:10 PM
  #432
Thanks...I will go ahead and wait until I run more mod stuff.
Old 03-22-2013 | 10:03 PM
  #433
JustWill75's Avatar
Aw man, I bought the bridge for no reason then because all I run is blinky 17.5 TC........
Old 03-23-2013 | 01:10 AM
  #434
what software do you guys use for mod?
f1o7x9 is offline
Old 03-24-2013 | 04:22 PM
  #435
Has anyone had a problem with the flow where the capacitor positive lead detaches itself from the capacitor randomly?..
Its either from vibration or someting as i havent crashed or anything..
Is it safe to use other capacitors? Like the works team one from LRP? Or do you have to use the big single?
Lionel S is offline
