RC10T4.1 Thread.
#2927
Since I needed a few parts as spares I went to ebay and got the parts to turn my 4.1 into a 4.2. Total off ebay was $75 shipped, most from the same chop shop seller. Here is a list of parts.
T4.2 conversion parts
Front End Assembly
9880
Steering
block, hex
7854
T4 front
axle, hex
3977
3/16x3/8
bearing
9882
C-clip, 3/16
3977
3/16x3/8
bearing
9892
12mm aluminum
clamping wheel
hex, rear (Yes a rear)
91201
SC10B
a-arms,
front
91202
SC10B
front shock
tower
Rear End Assembly
9864
FT aluminum
hub ( 0˚)
9917
Aluminum
hub A,
carbon
3977
3/16x3/8
bearing
7933
Crush tube
7935
.187x.196
bearing
9892
12mm aluminum
clamping wheel
hex, rear
Front End Assembly
9880
Steering
block, hex
7854
T4 front
axle, hex
3977
3/16x3/8
bearing
9882
C-clip, 3/16
3977
3/16x3/8
bearing
9892
12mm aluminum
clamping wheel
91201
SC10B
a-arms,
front
91202
SC10B
front shock
tower
Rear End Assembly
9864
FT aluminum
hub ( 0˚)
9917
Aluminum
hub A,
carbon
3977
3/16x3/8
bearing
7933
Crush tube
7935
.187x.196
bearing
9892
12mm aluminum
clamping wheel
hex, rear
#2930
Wayne
#2932
You might consider going to captured ball ends, else you have to keep up on ball cups as once they pop off on the inside they tend to pop off at all the wrong times.
#2933
I JUST REPLACED ALL MY BALL CUPS WITH RPM AND BALLSTUDS WITH ae TC5 BALLSTUDS
I SAW THE SC10 4X4 MOD BUT i HAVE SOME DUBRO'S LYING AROUND
AS FAR AS THE BRACE, JUST MOUNT BALLSTUD ONTO THE PLASTIC OR DO i NEED THE SC10 4X4 CAPTURED ENDS BECAUSE THEY ARE A BIT TALLER IF i GRIND DOWN THE U BRACE?
THANKS
THANKS
#2935
From: Dont get any more northwest than me..........
Front End Assembly
9880
Steering
block, hex
7854
T4 front
axle, hex
3977
3/16x3/8
bearing
9882
C-clip, 3/16
3977
3/16x3/8
bearing
9892
12mm aluminum
clamping wheel
91201
SC10B
a-arms,
front
91202
SC10B
front shock
tower
Rear End Assembly
9864
FT aluminum
hub ( 0˚)
9917
Aluminum
hub A,
carbon
3977
3/16x3/8
bearing
7933
Crush tube
7935
.187x.196
bearing
9892
12mm aluminum
clamping wheel
hex, rear
Front End Assembly
9880
Steering
block, hex
7854
T4 front
axle, hex
3977
3/16x3/8
bearing
9882
C-clip, 3/16
3977
3/16x3/8
bearing
9892
12mm aluminum
clamping wheel
91201
SC10B
a-arms,
front
91202
SC10B
front shock
tower
Rear End Assembly
9864
FT aluminum
hub ( 0˚)
9917
Aluminum
hub A,
carbon
3977
3/16x3/8
bearing
7933
Crush tube
7935
.187x.196
bearing
9892
12mm aluminum
clamping wheel
hex, rear
