FlySky GT3b Hack Tech Thread
#61
I believe you can download it from the Radio by going to Read, Current Tab, and then saving the file, however this didn't work for me, I have someone elses original firmware though, here you go.\
I am also having issues with the custom firmware, I have the GT3B-0.61 firmware, I am trying to get the steering to both have the 150% end point, however I can only select the end point for steering right. It's in channel 1 and esc is in channel 2.
Can anyone help me!! Thanks!
-Goat-
#62
Here is a link to a post that has a very user friendly manual for the GT3B/C hacks.
http://www.rctech.net/forum/radio-el...re-manual.html
-Goat-
-Goat-
#63
So for your guys/gals that have this radio...
1. How is it with out the mods for regular racing?
2. For those modded how is now for racing?
I am on the fence for this radio but do i need it modded for regular use?
Thanx!
Thanx!
#64
Just flashed to 0.6.1 and now the I have some glitching on channel one (steering). Once in a while the steering servo will move then return to center when there is no steering input (even set the radio down and it happened while the radio was sitting on a table). Never had glitching issues with stock firmware.
Trouble shooting steps taken:
Rebound the Rx and TX
Changed the number of channels from 3 to 2
Recalibrated the Tx
New Battries
Changed Servo
Added/Removed Glitch Buster
Changed to 0.5.0_3Channel and no glitching after an hour with the TX sitting on a table
Would appericate any trouble shooting tips.
Recalibrated the Tx
New Battries
Changed Servo
#65
Hi.
Need some advice please. I bought a hacked 3GTB of e bay. Not sure who did it but did say it wasn't worth doing anymore as it took too much time for the money he gets back.
While I have all the mods that i wanted like 72 model memory. One thing that I can't do is find a source to plug in my li po alarm. The switch is the obvious place to tap in but I can't access the wires that go into the switch.
Other wires i checked with a volt meter arent 12v so I cant tap into them.
Very frustrating as I just lost another li po battery from leaving it on. My fault but if the buzzer was connected this would have saved my li po.
Any advice would be much appreciated. I did ask on the 3GTB thread with no response!!!!
#69
#70
Cheers
Dan
#73
Hi all ya hack phreeks heehee I was jw if it is in anyway possible to make another receiver (other than the flysky ones) to bind to the radio, in particular, I have a bunch of the associated xp receivers! Thanks
#75
So im trying to put together an order on Digi-key or mouser for the parts to do the hack mod's and im having a hard time finding the correct pin header to install on the radio.
Im looking for a right angle 4 pin molex header with 1mm pitch correct? i keep coming up with 2.54mm pitch stuff
1Likes
