SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 02-21-2013 | 03:31 AM
  #2971
TomErickson's Avatar
Originally Posted by KC10Chief
I just bought two SC10 Factory Team trucks. I put the first one together tonight. I didn't realize that these things didn't have hexes on the axles. No biggie. I was going to ask about it, but see that there is some recent discussion on the topic. I used to race stadium trucks a long time ago and remember ruining more than a few wheels when the nut would come loose or something and that pin would round out the rest of the inside of the wheel.
What other upgrades should I make to make these things more reliable? What parts break a lot that I should have extras of? The only upgrade I've made so far, is to assemble it with Tony's Screws. Steel screws or whatever.
After the Wheel Hexes I would recommend the following spares or changes:
1) Front arms: Large impacts can break them. I use the carbon ones so they break even easier but I like the rigidity. I don't like the RPM arms but many people that bash or are not racing heavily will use then and they are really strong.
2) Ball Cups: I upgraded to the RPM ball cups especially on the rear camber links.
3) Rear Top plate: I upgraded mine with the STRC rear top plate for two reasons. With the stock plastic one the ball stud would eventually wear out the plastic. So the aluminum one was stiffer and stronger. Also the added weight is in the perfect location for rear traction improvements. I have more than 3oz. in my SC10 in the rear of the battery tray.
4) VTS Slipper: If you are running 10.5t motors or more you should get the improved slipper. Just more adjustability for various tracks.
I have been very happy with the durability of this truck after these upgrades. I am hoping that AE will release the needed upgrades into a new Factory Team kit (SC10.2?) that will include the new shocks and so on.
TomErickson is offline
Old 02-21-2013 | 05:06 AM
  #2972
lilws6's Avatar
Originally Posted by bds81175
So when you let off the throttle in the middle of a sweeper the rear end tries to swap ends with the front? How much drag brake are you running? I can get my truck to handle well on the rest of the track but maybe not so good on our sweeper. I've been raising the rear inner ball stud (lowering the rear roll center) to gain more traction on the infield of our track but if I'm not careful it violently traction rolls on the entry to the sweeper. That's when I switched to a gold barcode in front (recommendation of another racer at our track) to take away just enough turn in to stop the traction rolling. If I could control the throttle better (I'm a bit heavy fingered too), the green barcodes would be the fastest way around the track. However, the gold barcodes in front are more consistent.
Pretty sure i'm running little to no drag brake at all. I bought the alum. hubs in thinking maybe raising the rear roll center would help? Maybe i'm going the wrong way? I don't have problems traction rolling unless i'm coming into a corner off of a jump which we have two corners like that and i like to turn in to early with the truck in the air which will roll it when it touches down
lilws6 is offline
Old 02-21-2013 | 06:00 AM
  #2973
samuelsonmark71's Avatar
Funny you would say that, my track use to have an angled jump coming off the straight. I would pitch the truck about 45 degrees in the air and 99% of the time it would land just fine to turn the extra 45 degrees for the upcoming double. I throw the truck all of the place in air and have no problems
samuelsonmark71 is offline
Old 02-21-2013 | 06:51 AM
  #2974
JohnnyPetz's Avatar
Are you sure it's not a balance issue? Left - Right balance is very important to keep straight
JohnnyPetz is offline
Old 02-21-2013 | 09:12 AM
  #2975
ae-Dan's Avatar
+1
ae-Dan is offline
Old 02-21-2013 | 09:42 AM
  #2976
mxracer458's Avatar
i know for me,i have a novak kinetic esc and a small reciever on the other,i could tell it was out of balance,put a 1/2oz next to the reciever and it helped the truck everywhere.
mxracer458 is offline
Old 02-21-2013 | 10:19 AM
  #2977
Red78's Avatar
what would be a good place to start with the gearing with a viper 13.5 motor? this would be raced on a smaller track indoors
Red78 is offline
Old 02-21-2013 | 02:52 PM
  #2978
I didn't even know that this is possible, ofr had anything to do with the balance of the vehicle...cause I have the esc on the same side as the receiver....I am gonna change it over now lololol.....
theblitzkidd is offline
Old 02-21-2013 | 02:56 PM
  #2979
JohnnyPetz's Avatar
My buggy and trucks left/right weight percentage is in within 100th of a gram.
Old 02-21-2013 | 03:05 PM
  #2980
lilws6's Avatar
The balance should be good everything is in the battery tray. I as well can pitch the truck into a turn mid air and come out fine its when i usually come up the step up straight and turn the wheels mid air into the turn causing the truck to lean to the outside and come down on the outer to wheels. when they grab traction they cause the truck to roll. the truck flies level everywhere else unless i turn the wheels midair I'm sure you've seen your truck or even buggies do this. buggies are more noticable it has to do with the gyro effect of the tires. the mid sweeper off throttle has me stumped tho maybe to stiff of shock oil?
lilws6 is offline
Old 02-22-2013 | 10:58 PM
  #2981
ae-Dan's Avatar
Maybe the update will be called the SC10T???
ae-Dan is offline
Old 02-23-2013 | 05:21 AM
  #2982
Nicholas Muelle's Avatar
what is a good gearing for a 6.5 motor in a SC10, i race competetivly and the track is Leisure Hours Raceway. They have some jumps.
Nicholas Muelle is offline
Old 02-23-2013 | 08:33 AM
  #2983
koopesv's Avatar
where is the sc10.2 Im getting
koopesv is offline
Old 02-23-2013 | 08:41 AM
  #2984
TimMo846's Avatar
I've been there on a few of their previous layouts and I ran a 87/19 gearing on my 6.5 and had plenty of power(low and high end). Not sure what might be a good one for what their layout is now.
TimMo846 is offline
Old 02-23-2013 | 10:01 AM
  #2985
platgof's Avatar
Default SC10B
I put the front end on and you are limited by the holes you can use unless you dremel the post to get the other two top mounts, the outboard one has full support. It is much lower as I had to go up 3 holes on the post for the body to sit properly. I should be racing tonight and will let you know what I think. I placed 3rd in the b main last time I race tweo weeks ago. Got these from Hobby People in one week.
platgof is offline
