SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 02-19-2013 | 11:17 AM
  #2926
slashman404's Avatar
Default Big bore spring conversion
I am switching my stock V2 shock springs and doing the big bore conversion. What associated spring set ups are most using on a sc10? On my T41 I have losi green and yellows on but want to use associated springs on my sc10. I am racing right now on a ight indoor med to high bite clay track. Thanks
slashman404 is offline
Old 02-19-2013 | 11:25 AM
  #2927
Wildcat1971's Avatar
Tech Prophet
I would get the black and green rears and the white and grey fronts
Wildcat1971 is offline
Old 02-19-2013 | 12:38 PM
  #2928
ButtDyno's Avatar
Just got her done last night. Fixing to go to the track to dial it in.
ButtDyno is offline
Old 02-19-2013 | 01:37 PM
  #2929
bds81175's Avatar
Moderator
I've got AE green front and rear and so does my son.
bds81175 is offline
Old 02-19-2013 | 01:39 PM
  #2930
bds81175's Avatar
Moderator
Sweet! Dig the ride! One of the first things you will need to do to get it dialed is switch out the front tires. The stockers are round and that's about the only good thing you can say about them. What type of track are you running on?
bds81175 is offline
Old 02-19-2013 | 03:18 PM
  #2931
ButtDyno's Avatar
Running on a indoor clay track medium/small size tight with small jumps.
Thanks-
ButtDyno is offline
Old 02-19-2013 | 03:48 PM
  #2932
Nice ride man!!! Gotta luv the sc10
theblitzkidd is offline
Old 02-19-2013 | 03:56 PM
  #2933
Ranger411's Avatar
Wondering how fast I should rebuild my ball diff. I did it per the video on this site about 6-7 weeks ago. I race once a week 2 qualifiers and then a main or two depending on if I bump. The reason I ask is the diff seems to want to back of a 1/4 turn or so every other race, or is that normal?
Ranger411 is offline
Old 02-19-2013 | 04:52 PM
  #2934
Looks great!! Did you do the paint job? I'd cut the front body posts down a bit. Just looks so "rookish".
Gonna' need tires front and rear. The stockers are great for propping up your car while you change out the new tires, rebuild shocks, adjust clutch, etc.
And how did you first run go for ya'?
shagnat is offline
Old 02-19-2013 | 06:09 PM
  #2935
CraigMBA's Avatar
I'd replace the nut opposite the diff screw ASAP. It shouldn't back off at all.
I can get about five races out of mine before it gets notchy and I have to clean it and resand the thrust washers and diff rings.
CraigMBA is offline
Old 02-20-2013 | 05:13 AM
  #2936
ButtDyno's Avatar
Thanks man...have been eye ballin these trucks for a few months.
Yep I did the paint job...took me about 6-7 hours on an off over the weekend. Im really happy with it for being my second paint job. I was wondering about cutting the posts...no real neee for them being that tall up front huh.
Yep, fixing on getting some gold barcodes on Thursday....I was in a hurry to leave house to run errands an I brought the wrong transmitter. So no practice was had yet.....noob mistake fml.
Thanks form the comments fellas!
ButtDyno is offline
Old 02-20-2013 | 05:27 AM
  #2937
bds81175's Avatar
Moderator
I've not had much luck with gold barcodes on indoor clay anyway. Our track here is medium/high bite, smooth and moist. If you are a new racer make sure you talk to the fast locals about what tire they are using and what sauce they are putting on it, if any. That's the most important part about tuning the truck. Either way, let us know how the first run goes!!
bds81175 is offline
Old 02-20-2013 | 05:29 AM
  #2938
Does the SC10 FT come with aluminum "zero" hubs?
nv529 is offline
Old 02-20-2013 | 05:39 AM
  #2939
Tech Prophet
I think the FT comes with RTR plastic hubs.
Old 02-20-2013 | 07:22 AM
  #2940
ButtDyno's Avatar
I was chatting with the " fast" guys at the track an he pointed me to the barcodes. I saw he was running them and asked if they did good...he said its the only tire he runs on the truck at the track. We'll give them a shot and see. I'll keep you guys updated on the maiden practice run!
Thanks-
ButtDyno is offline
