Question on ESC's, brushless, and lipo's.
I'm new here and I want to convert my Losi 1/18 Desert Truck to brushless but I'm still a little confused on what I need to get.
I know I have to get the C ratings on stuff correct. The Lipo and the ESC need higher continuous and burst c rating than the motor, right? Does the the lipo need higher c ratings than the esc or vise versa?
I'm thinking about getting this motor, Tacon 2030-18T Brushless Motor 5200KV, but hobbypartz doesnt' give the continuos and burst c ratings on motors. Is there a way to calculate that so I know what lipo and esc to get?
Also, do motors usually come with a pinion gear or do I have to buy that separately?
Usually motors will require a pinion, meaning you can either buy a new one or use the one from the existing motor, assuming that they are the same bore size.
Your battery should have at least the equivalent amp rating as the ESC.
In terms of c ratings and burst ratings...higher is always better, but not often needed. I know that with my Traxxas mini rally's they require some batteries that are around at least 30c. Batteries getting hot or even warm is a good indicator that you need more current flow through. The Lipo batteries that are in my racing vehicles (listed below) never get the slightest bit warm.
From what I've found it's pretty hard to find a high C rating battery for the mini vehicles. Most will either come in at 20c or 30c. Or you could go with max amps batteries where they list their true c rating as 100c, you just pay at least twice as much.
