JConcepts Thread
#5822
Hideeho
I've asked this before, but that was before the B4.2 & b44.2 were anounced with hex drives.
Has any thought been given to making a Rulux wheel for 1/10 buggies with 12mm hex drive? I love my Rulux wheels (run them on 1/10, 1/8, & formerly on sc) & haven't converted to hexes on my B4.1 only because of them.
#5824
#5825
Update: AE axles and Avid hexes work. No shims, no wobbles....
If I would have known this was an issue from the start, I would have bought JC Hexes too. Hence why I said it would be nice to maybe include that little tidbit somewhere on JC site/ product info.
I still may buy the JC hexes.......The axles are REALLY nice compared to stock AE.
Do you know if the sc10 has the same issue cause I just ordered JC axles with avid hexes. I did get JC wheels also though.
#5826
#5827
You should be able to tell when you get it together, see if you can see axle sticking out past the wheel (no threads). If so, I bet the nut won't fully tighten. That is how mine looked upon further inspection.
The first time you tighten the wheel nut, don't crank on it too much. When I really turned mine, since the nut was seated to the axle but not tight between hex and wheel, the hex would actually spin in the wheel with some muscle.
#5828
Have no clue bro... we are talking about two different class vehicles.
#5829
The flathead screws have a larger surface area giving better support. I know one trick we always did (and I still do) to the old gold tub chassis was to counter sink all the screw holes on the sides and rear of the chassis to use flatheads. They stayed tighter and kept the chassis tweak to a minimum. I am sure there is more than enough room to have all 4 screws as a flathead.
#5830
Ah, ok, I understand now. Thank you.
#5831
http://www.youtube.com/watch?feature...&v=iKL7YtNpsQQ
Video from Reedy Race on new Jconcepts products
#5833
Just wanted to know the benefit of running stock vs closed cell inserts are guys mixing them up 2 stock 2 closed cell thinking of trying this out with my new set of pressure points for stadium truck? What have you guys been having luck with?
#5834
In stadium truck, insert is so huge. For our medium bite indoor dirt track, I don't even want to run my truck with open cell it's so horrible compared to closed cell. Buggy, open cell front is good, but on truck, open cell front isn't as good as closed cell from my experience.
#5835
For what it's worth...
SC10 front axles (stock, with NO clips) worked perfect with Avid hexes.
I installed the JC axles, with the same Avid hexes and I have no runout/wobble issues.
Ran JC Hazard +3 wheels in both cases.
495Likes
