RC10B4.1 FT/WC
I'm guessing with any update, the big bores will be the center piece, maybe with some new towers etc.
So if your happy with the V2's get the kit now. I have seen some ridiculously low prices, so know is a good time.
Otherwise your guess of what's yet to come (if anything) is as good as anyone else's.
im also gonna get some new springs when i get it and want too run the new 12mm bb associated springs, what should i run front and rear for indoor clay tracks ?
On corner exit, the test is very simple. If the car is loose and the situation gets worse when you apply more throttle, the roll center is likely too low and needs to be raised to reduce roll. If the car is loose and the situation gets better when you apply more throttle, then the roll center is likely too high and you need to lower it to increase roll.
Lower the roll center by adding washers. Raise the roll center by removing washers.
Before you do ANYTHING hunting for traction with your car, ensure your shock ends are screwed all the way in. 2wd cars without sway bars are extremely sensitive to shock down travel. Total chassis roll is limited by shock down travel much like a sway bar. Two limiters is the ticket on the b4.1, big bore or small bore, with the ends screwed all the way in obviously.
Shouldn't take too long, theres like 7 screws in the front along with all the rear bottom screws and the few near the shock tower... Just remount and all your electronics.
For servos I love the XP series, 1015 all the way (have used the 1313 in there and to be honest I could not see a difference in speed). Motor I like the Reedy and LRP but hear the Schurr (SP?) are really good as well.
I think the 1015 is great but for some reason I just like my Airtronics 94770's. The 1015 torque is way better speed is just a tick better on the 94770 though. Only had one Savox that my hobby shop sold me and was so tight in B4 moved it into SC and it works great and for under 40 bucks. Have not tried any high dollar Savox's though. My only rant that I have with them all is you don't get a nice single arm servo mount especially on the 1015 at $100.
i want a new fresh 2wd buggy kit really soon, and obviously associated all the way!
but everyone knows that the b4.2 or b5 whatever its gonna be is coming any day now and am wondering if i should wait for that or get the b4.1 now, im not into all the hype of the big bores and will run the v2's that come with it just with big bore springs so im not worried about that, do u think id be fine too get this now and just get the b4.2 when it comes out cause i dont want too waste money.
but everyone knows that the b4.2 or b5 whatever its gonna be is coming any day now and am wondering if i should wait for that or get the b4.1 now, im not into all the hype of the big bores and will run the v2's that come with it just with big bore springs so im not worried about that, do u think id be fine too get this now and just get the b4.2 when it comes out cause i dont want too waste money.Thanks
It's all speculation because someone heard Cavalaria was taking pictures of his buggy for a new box. I think it's one of those things if you truly believe in it will happen. Would be nice to see a new buggy though with all the new stuff on it.
I only offer general information. Car set ups and spring choice are beyond my pay grade. I think it's best to ask one of the other experts on here.
maybe the 4.2 will get google maps!
I've never tried them and I can't say that I have seen them turn up anywhere around here. It's pretty much all JC / Proline for 10th scale and add AKA in the mix for SCT and 8th scale by me.
I wouldn't be opposed to trying them... I just am trying to stay with one brand for now to make things a little easier for me. I typically run JC stuff so that I'm not second guessing 'should I be on proline' all the time.
Has anyone else tried them?
Thanks!
