YOKOMO Touring Car BD-7
#1351
Given I lack all sorts of skills as a driver I really haven't experienced the consistency issues with the BD7 in 17.5. It seems the base carpet setup works well in low to med conditions but in high bite conditions it has too much traction. A couple of things seems to work when the traction has come up for me.
1. When the traction comes up I just swap to Jaco Blues from Sweep QTS32. This seems to work for the most part but only works if your rules allow for a few different spec tires.
2. I also found that running the wider 44.2 blocks up front, running the longer camber link positions up front, and using the inner hole on the steering blocks (reduce ackerman) works well if I had to stay in the same tire (Sweep QTS32).
On a different topic, how low of an FDR have most people been able to achieve with the BD7? With a 96t spur I can only fit up to a 50t (3.84FDR). Is anyone running a 84t or 88t spur?
#1352
Trader Rating: 102 (100%+)
#1353
#1354
That would make a uber dialed BD-7.
#1355
#1359
I really don't get what some guys are saying about the car being on and off.
This car is dialed. A local guy that just started out has had his for a couple months and the car just gets better and better. The BD7 is so consistent I'm actually building mine right now to replace my tamiya 417x which I felt was a lot more hit and miss but I still love.
