Tamiya TRF415
#4291
Tweak
So how do you guys avoid tweak on the 415? I noticed that one good hit and the car tweaks significantly. It seems as if all the tweak is coming from the front of the car where the spacers connect the top deck with the mid deck. Once I loosen the screws, you can see the top and mid decks snap back to place.
#4292
Re: Tweak
has anyone counter sunk the top deck? and if you have.. does it help?
#4293
Another option that has been done by Dsrbltoys is to countersink all of the locating points on the mid decks. Not sure how effective it has been.
I have gotten in the habit of taking the tires off each round and loosening the topdeck on a flat plate and then putting it all back together.
#4294
Hebiki - I'm already using countersunk screws on the topdeck!. Countersinking the topdeck won't help....the screws don't shift there. The screws are locked into the topdeck, but upon impact, the screw bend a little and the blue spacers between the top deck and mid deck shift.
#4295
#4297
Re: Tweak
Maybe? Something to consider!
Just my 2$
#4298
Re: Tweak
linger crash?!
#4299
1/8 diff balls
Will 1/8 diff balls fit the diff pulley? 1/8 is 3.125mm if I am not mistaken. It is more accessible to me than 3mm diff balls.
#4302
Whoa.....looks like Tamiya decided to bring out "another" car. Saw a pic on the net...the $415MS.
It looks good. Not sure what else is new besides the suspension. Wonder if they're gonna release an update kit with all the mods. for you $415 owners.
#4303
1/8 Diff Balls
elnitro,
I was hoping for the same as I could not find any 3mm Diff Balls anywhere. The one hobby shop that has them I frigen forgot to buy them at and they are over 100kms away. I just bought some RC12L 1/8 balls and tried them. They do not fit. Shoot!
1/8" = 3.175mm , BTW
Need exactly 3mm for those inner holes on the diff pulley.
#4304
Re: 1/8 Diff Balls
Originally posted by 190mph
elnitro,
elnitro,
#4305
Diff Balls
Actually a good place to buy diff balls for Silicon Nitride if you don't mind spending up front to buy a bag of 100 is Salem Specialty Ball Company. There is no minimum order. I am going to order some 100 packs of 3/32" and 3mm.
I had a quote in March 2002 for 3/32" at $0.64 each for 100 qty that I was going to use for the TC3. That is grade 5 ones. 100 pcs will last for a long time.
I am going to order some this week.
