RC10B4.1 FT/WC
Old 11-24-2012 | 06:14 PM
  #24541
Originally Posted by njnewc
How often do u guys clean ur motors? What do u use? Any tips? If u use electrical cleaner do u spray the bearings? If so what do u use to re lubricate them? Thanks
dont use electrical cleaner on any part of the motor, just some compressed air, clean/oil bearings. (if brushless)
sjenkins97 is offline
Old 11-24-2012 | 06:15 PM
  #24542
Venom1836's Avatar
I am also curious about this.
I am running a Reedy 7.5 with many vents in the motor and two of my local tracks are very dusty.
Venom1836 is offline
Old 11-24-2012 | 06:34 PM
  #24543
njnewc's Avatar
So what r u cleaning and lubing the bearings with? How often? Do u tear it down?
njnewc is offline
Old 11-24-2012 | 07:00 PM
  #24544
i will tear it down and air it out 1 or 2 a year is all. i dont run on really loamy tracks. i will spray bearings wilth motor spray and lube with bearing oil or 3 in 1 oil.
Old 11-24-2012 | 07:04 PM
  #24545
Matt Ward's Avatar
I clean my Reedy atleast once every 2 weeks and my Orion once a month. They don't need cleaned that often I'm just picky. I suck but atleast my car is clean.
Matt Ward is offline
Old 11-24-2012 | 07:13 PM
  #24546
66Racer's Avatar
Thanks I will inquire with AE Monday. In the meantime think I'm gonna get the MIP aluminum one, anyone try this out?
Originally Posted by beidle99
Look towards the back of your instructions it tells you what spacers to use with different servos. They are a tight fit. Contact AE on the top shaft, they will get you one sent out right away. I doubt that they will send you arms instead, but its worth a shot.
Lol yeah that's why I posted. My manual says turn to page 40 but there was no page 40. Looks like my z8800s fit. I swore it wasn't going to but luckily it did I just need to power my electronics and hope it still works.
66Racer is offline
Old 11-24-2012 | 07:17 PM
  #24547
RC_nooberton's Avatar
Lol! Good sig line material.
RC_nooberton is offline
Old 11-24-2012 | 07:36 PM
  #24548
Matt Ward's Avatar
Get the x factory top shaft.
Old 11-24-2012 | 07:55 PM
  #24549
njnewc's Avatar
So how do u clean it and what r u lubing ur bearings with?
njnewc is offline
Old 11-24-2012 | 08:59 PM
  #24550
Matt Ward's Avatar
Thumbs up
I spray it with Performance Plus 3 and I use a goat mop (it's actually just a brush from AC Moore). Then re-lubricate the bearings with Parma T.Q. Bearing Oil.
Old 11-24-2012 | 09:01 PM
  #24551
Venom1836's Avatar
How much does the standard amount of B4.1 slop affect performance?
Old 11-24-2012 | 09:16 PM
  #24552
njnewc's Avatar
Thanks for the info Matt
njnewc is offline
Old 11-24-2012 | 09:18 PM
  #24553
Originally Posted by Tradin Paint
If you truly have a bent top shaft AE will replace it no questions asked. First take a look and make sure that you have the slipper pads on correct. Sometimes in the build the pads slip out of the slots in the spur gear and this may be your issue
Regarding the servo. It does use the std servo size, it is just a very tight fit. You should be able to use your JR servo
Good luck
I had to dremel a little off the mounting tabs to get my Jr 9100s to fit in my b4.1. Not much, you can't even tell really if you do it neatly
associatevalley is offline
Old 11-24-2012 | 09:19 PM
  #24554
idrummerboy13's Avatar
don't let it get to your head it happens. And its quick.
still an amazing car
idrummerboy13 is offline
Old 11-24-2012 | 09:27 PM
  #24555
Venom1836's Avatar
What exactly do you mean?
