SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 11-11-2012 | 04:03 PM
  #1681
Wildcat1971's Avatar
Tech Prophet
hmm I tried them and disliked it on dirt
Wildcat1971 is offline
Old 11-11-2012 | 04:07 PM
  #1682
Hey guys, what's the basic chassis set up for 17.5 blinky? also has anyone played around with BB springs on standard shock like everyone was doing before the BB shocks on the b4.1?
nv529 is offline
Old 11-11-2012 | 04:08 PM
  #1683
Tech Prophet
I run the AE bb springs. Definetly feel smoother
Old 11-11-2012 | 04:11 PM
  #1684
which ones?
nv529 is offline
Old 11-11-2012 | 04:15 PM
  #1685
Tech Prophet
white fronts and green rears
Old 11-11-2012 | 05:15 PM
  #1686
LOSI123's Avatar
Has anyone found a upper spring coller for the v2's that dont allow very end of the AE 12mm spring to pop out?
I have Traxxas upper collers and RPM ones and the AE green rear 12mm spring very end bit pops out the side (the collor is to small /loose)
I know most will say just get the big bore shocks but I was hoping some one would now of some upper collars that dont do this.
The avid springs must fit a bit tighter as they dont do it. (internal diameter must be a bit smaller)
I dont want to lash out for GHEA or AVID upper collares just to find they still do it, as it changes ride height with it poping in and out etc...
LOSI123 is offline
Old 11-11-2012 | 05:23 PM
  #1687
Tech Prophet
I dont like the losi uppers. I have them and they suck. get the traxxas uppers. I have had no issues with ae or losi lowers.
Old 11-11-2012 | 05:28 PM
  #1688
LOSI123's Avatar
Sorry I must have been day dreaming as I got mixed up, It is with the Traxxas uppers that this happens
LOSI123 is offline
Old 11-11-2012 | 05:30 PM
  #1689
Tech Prophet
my springs didnt pop out. The collars fall out when I take the bottoms off. but they never pop out while racing. I am using the traxxas uppers and the AE bb lowers.
Old 11-11-2012 | 06:27 PM
  #1690
mxracer458's Avatar
#2 pistons?what shock oils in the shocks
mxracer458 is offline
Old 11-11-2012 | 06:32 PM
  #1691
Tech Prophet
Sorry. I was running cav's nats setup with the springs I listed.
http://teamassociated.com/pdf/cars_a...lieri_ROAR.pdf
Old 11-11-2012 | 07:00 PM
  #1692
LOSI123's Avatar
Try pushing the spring to the side and watch closely to the very end/tip of the spring
LOSI123 is offline
Old 11-11-2012 | 08:46 PM
  #1693
Tech Prophet
right, but the springs dont normally have side tension. I finish the races with every intact. The springs dont look scuffed up from rubbing. I guess it is a non issue for me.
Old 11-12-2012 | 12:37 AM
  #1694
IRM616's Avatar
I have a t4 can i convert that to an sc10 ? If so is it the same? And what do i nerf
IRM616 is offline
Old 11-12-2012 | 06:51 AM
  #1695
VegasHB's Avatar
Originally Posted by MD
When you look at most of the setup sheets from Associated, the drivers use some kind of weight in the rear.
Hate to bring back the weight thing but you need to also realize that they have minimum weight requirements to meet as well and they all run mod motors. 17.5 blinky is weight savings nirvana.
Regardless weight does help with consistency and is much easier to tune with than balancing out the suspension to the chassis. The lighter you go the lighter your shocks usually need to be as well. Not to many pro setup sheets that offer a starting point.
VegasHB is offline
