RC10B4.1 FT/WC
Old 11-11-2012 | 07:49 AM
  #23836
EJF's Avatar
EJF
My B4.1 wc seems to go need the rear inner hub bearings replaced too often, is this normal for the car? I also heard of the hubs some kits were not made correct, any fix for this besides buying new hubs?
EJF is offline
Old 11-11-2012 | 07:51 AM
  #23837
pballer2777's Avatar
i just picked up a b4.1 rtr and was wondering what tuning oprtions are needed? springs, etc
pballer2777 is offline
Old 11-11-2012 | 07:59 AM
  #23838
Wildcat1971's Avatar
Tech Prophet
if you dont need c hubs. try the b44 plastic hubs. If you really like the alum hubs. try avid bearings and put some grub screws in.
Wildcat1971 is offline
Old 11-11-2012 | 10:00 AM
  #23839
Wild Cherry's Avatar
[QUOTE=EJF;11428313]My B4.1 wc seems to go need the rear inner hub bearings replaced too often, is this normal for the car? I also heard of the hubs some kits were not made correct, any fix for this besides buying new hubs?[/QUOTE
No problems with production of the hubs ,assuming you have the blue metal Ae hubs.
The inside bearing wears & needs replacement more often then the larger outside bearing.
Main reasons for hub bearing failure is big hits & hard landings on one wheel...
Wild Cherry is offline
Old 11-11-2012 | 10:01 AM
  #23840
Allen720's Avatar
I assume you cannot use a set up from a b4.1 wc to set up a b4 without the extended chassis?
Allen720 is offline
Old 11-11-2012 | 10:09 AM
  #23841
F18engineguy's Avatar
Default Spring cups
Do you guys think there is any need to keep the extra spring cups that came with the big bore shocks? I only used the ones for the b4&b44. Do you think the others might be a tuning option in the future or will they just be good for the truck applications?
F18engineguy is offline
Old 11-11-2012 | 10:17 AM
  #23842
F18
Ae just thought ahead with the spring cups .
Racers are always are trying different springs from other manufactures.
Keep the other size cups handy if you wish to use different springs...
Old 11-11-2012 | 10:59 AM
  #23843
CraigMBA's Avatar
It's so you can adjust the free height of the spring so you can get the ride height correct if you want to use a different (longer or shorter than designed) spring.
For example, if you want to use a buggy front on a stadium truck you can use the larger offset cup. Or, if you use the longer Kyosho springs, you can use the smaller offset cup.
It's mostly a stadium truck or short bus thing.
CraigMBA is offline
Old 11-11-2012 | 02:26 PM
  #23844
Has anyone used the bfast teflon shim kit on their b4?. Like on the front and rear to tighten up the slop in the hub/hingepin areas?
nitro0619 is offline
Old 11-11-2012 | 03:37 PM
  #23845
scr8pn4205's Avatar
i am new to the 4.1 worlds camp. just wondering are all the parts plastic or graphite ( arms, chassis etc)
scr8pn4205 is offline
Old 11-11-2012 | 03:38 PM
  #23846
Tech Prophet
100% plastic
Old 11-11-2012 | 04:38 PM
  #23847
Venom1836's Avatar
I have been talking with AE via Email.
They say that if I don't purchase and send them a LRP ESC before the board replacement it will cost about $100 dollars to get a new board.
Should I hurry and get an SXX TC V2 before the offer ends or wait and get the new FLOW ESC along with a Reedy Sonic 7.5.
I will only be running MOD 2WD buggy with a full sized 25C Reedy LiPo and XP 1015 Servo.
They said that the old ESC's will be replaced by the Flow.
I really don't want to make an investment into a nice ESC/Motor and have it become outdated.
Thanks for reading and PLEASE help me out
-Venom
Venom1836 is offline
Old 11-11-2012 | 05:25 PM
  #23848
-Venom
If it were me and I could wait I would. Got too see a flow this saturday and seems very nice.
tonyd is offline
Old 11-11-2012 | 05:31 PM
  #23849
Tech Prophet
do they have an eta on the flow? I saw pictures of it like 3-4 months ago.
Old 11-11-2012 | 06:06 PM
  #23850
Does it matter? All you're going to do is talk about it everyday and then bitch about the price once it does come out and then never end up getting one
PFKAOG is offline
