Spektrum receiver question about plugging >
Old 10-28-2012 | 06:18 PM
rsxskyd's Avatar
Default Spektrum receiver question about plugging
I have a spektrum sr300, I have my transponder in aux, I am looking to plug in the spektrum glitch buster in my receiver but the only open space is BIND? Can I use this plug and will it work properly??
rsxskyd is offline
Old 10-28-2012 | 06:29 PM
King DORK's Avatar
That will work just fine.
King DORK is offline
Old 10-29-2012 | 09:56 AM
rsxskyd's Avatar
Ok so then it doesnt make a difference which one its plugged in, it works the same in either?
rsxskyd is offline
Old 10-29-2012 | 05:19 PM
King DORK's Avatar
Yes, that is correct.
Old 10-30-2012 | 07:19 AM
rsxskyd's Avatar
Do any of you guys know if it makes a difference wether I get the Novak one or the spektrum one?? Is one better or more reliable than the other??
I did do research but not too lucky.
rsxskyd is offline
Old 10-30-2012 | 07:51 AM
T. Herwig's Avatar
I can't speak for the Novak one but I've used the Spektrum one for 2 years now with no issues whatsoever.
T. Herwig is offline
Old 10-30-2012 | 07:55 AM
racer1812's Avatar
Super Moderator
Either one will work just fine and you won't notice any difference, IIRC the Spektrum one is a little cheaper though.
racer1812 is offline
Old 10-31-2012 | 09:21 AM
+1 I've used both and either is fine.
nubie-wan is offline
Old 10-31-2012 | 09:33 AM
lbenton's Avatar
FWIW, you can also tie a glitch buster in with a "Y" cable or splicing it in on something. I have had good luck just splicing it to my motor fan.
lbenton is offline
