JConcepts Thread
#5537
is the idea that the fumes will loosen the CA when you use a couple mm of acetone? Yeah, the tires are on some spoked rims and the spoke cracked. The rims wont last 2 heats before they snap off. The tires are at like 90% tread though, so I dont really wanna toss them. Anyway, back to the few mm of acetone. If the acetone touched the foam, wont the foam pull it up like a sponge?
#5538
#5542
Anybody try the inverse wheels? how do they compare to the mono wheels? I used the mono wheels a while back and thought they were a little stiff...
#5545
#5547
I've "felt" the inverse and would say they're stiffer than my rulux or proline dishes.
never ran monos so can't help directly help with that.
Ordered some (inverse) I like the inside being smooth..the matte finish, not sure on that but after a few pipe rubs and cleanings all rims are dull anyway
#5549
Paul, have you guys gotten a chance to look at the wing mounts for the RB6 and see if just maybe the Associated wing mounts you guys make will fit?
I apologize if it has been asked before and I will accept my rightfully deserved harassment.
#5550
495Likes
