Team Associated SC18.... >
Old 10-17-2012 | 02:37 AM
  #736
My stock servo is "R.I.P", with what servo to replace the old one ? A link from Tower will be good if someone is kindly to help me.
lamav4 is offline
Old 10-17-2012 | 03:59 AM
  #737
I've had pretty good luck with the EXI D213F servo:
http://www.hobbypartz.com/9gexidimeges.html
The best part is that it's a metal gear servo, so I remove the sloppy servo saver and mount directly off the included servo horn so I don't have any centering issues after bumping corners or other cars on the track, even better is that it's a digital servo which allows better precision if you are using expo on your steering, oh and it's significantly faster than the stocker
billdelong is offline
Old 10-18-2012 | 05:10 AM
  #738
Ok, thx, I think I will go with Hitec HS-65MG, a brushless combo its on the way.
This week, the new 1:18 track will be ready and next week the first contest.
What parts to order to have with me in case something goes bad ? What are the weaknesses in these cars ?
lamav4 is offline
Old 10-19-2012 | 06:37 AM
  #739
Rodarbal's Avatar
The only part I broke (twice) was the steering rack. Get an steering rack assembly, Associated p/n 21322. Should be about $4 to $5 USD. The only other failure I've seen on other cars were drive belts, but that particular racer was running a 4-pole brushless on a 3S lipo. Never hurts to have an extra on hand. Good luck!
Rodarbal is offline
Old 10-23-2012 | 08:47 PM
  #740
ABN Hoosier's Avatar
couple of questions.
Does a standard 2S lipo fit on this lil dude? Is the receiver normal size? Wanted to put my own in it. Thanks
ABN Hoosier is offline
Old 10-24-2012 | 03:52 AM
  #741
No, 1800mAh is the largest 2S pack that I've been able to fit, you might be able to get a 2200mAh pack to fit with some mods to the battery holder. Most packs are around $10-$15 across the net.
Yes
Old 10-25-2012 | 04:33 AM
  #742
In a way... Also 1/10 ESC fits
Attached Thumbnails Team Associated SC18....-12102012891.jpg   Team Associated SC18....-12102012892.jpg
lamav4 is offline
Old 10-25-2012 | 05:07 AM
  #743
I'm waiting, what I ordered for the car :
- combo EzRun 18A, motor 4500kV;
- servo Hitec HS-65MG;
- Associated steering rack assembly p/n 21322;
- lipo;
- belts.
Hope is enough.
lamav4 is offline
Old 10-25-2012 | 11:43 AM
  #744
Anyone willing to sell a SC18 roller?
sabongi is offline
Old 10-29-2012 | 07:39 PM
  #745
ummmm, nope
Old 10-30-2012 | 05:03 AM
  #746
The HobbyWing 60A ESC's designed for 1/10 cars have the same physical footprint as their smaller 25A ESC's and would have no problem fitting the SC18 without any special mods:
Old 10-30-2012 | 07:45 AM
  #747
Rodarbal's Avatar
ummmm, nope
LOL, as Bill has shown, a standard ESC (ie. one used in a 1/10 car) will fit, but a LiPo intended to fit a larger scale car will not.
Rodarbal is offline
Old 11-05-2012 | 12:33 AM
  #748
MRCCC's Avatar
BRAND NEW ROCKSTAR SC18 Body make an offer see link. http://www.rctech.net/forum/r-c-item...5-shipped.html
MRCCC is offline
Old 11-05-2012 | 08:27 AM
  #749
How to tight or lose the two belts ? Is ther a video ? I never had a beld driven car before.
lamav4 is offline
Old 11-06-2012 | 03:59 PM
  #750
You cannot adjust the rear belt tension, but shimming the rear differential can help to ensure it is aligned best. Run the front belt as loose as possible without it slipping. Unless you have way too much power, you can run the tensioner at the lowest setting.
burnineyes is offline
