RC10T4.1 Thread.
Old 10-24-2012 | 06:50 AM
  #2371
Originally Posted by aeRayls
correction
JC axle=sc10 rear hex
Really?
Yes jc site states to use rear sc10 hexes w their axle
nitro0619 is offline
Old 10-24-2012 | 06:56 AM
  #2372
Wildcat1971's Avatar
Tech Prophet
This is what thew JC website says...
Mono - T4.1 - 12mm hex F&R wheel - available in white and fluorescent yellow - 4pc.
Part # - 3354W
(Fits Team Associated T4 line of vehicles)
(requires JC part #2170 front axle)
(#2081 clamping hex adaptor front and rear)
(#9880 AE inboard hub conversion)
I originally read that as sc10 front and rear, but you are right. They are saying the rear hex front and rear. As stated with the part number.
Wildcat1971 is offline
Old 10-24-2012 | 11:27 AM
  #2373
CONFUSING!!! It was much easier to buy aluminum hexes for my SC10. One set works with all wheels.
I will be using AE steering block and axle. So it looks like I need two sets of ASC9890 - 12MM ALUMINUM CLAMPING WHEEL HEX, BUGGY REAR (B4.1/B44.1)
If I want to use AVID then I neeed two sets of AV1002-RR - B4.1 Clamping 12mm Hex | Rear
If I want to use Jconcet I need two sets of SC10 front.
I plan to buy Associated hexes. I have had JConcepts and Associated on my SC10 and the Jconcepts easily strip out. They need to supply a 6mm instead of a 4mm screw.
Cueball22 is offline
Old 10-24-2012 | 11:54 AM
  #2374
Tech Prophet
if you want to use the AE axles. I beleive it is sc10 hex in the rear and b4 rear up front. Did you read somewhere that it is b4 rear all the way around?
Old 10-24-2012 | 12:01 PM
  #2375
Tradin Paint's Avatar
You guys are making this way too confusing. First determine what wheels you are going to run and then follow that manufacturers recommendation for what parts are needed. Both DE and JConcepts have listed what is needed for their products
Tradin Paint is offline
Old 10-24-2012 | 12:07 PM
  #2376
Tech Prophet
jc only lists their axles. I didn't see a reference to the AE axles. Brent from AE did say what needs to be done in his setup sheet though.
Old 10-24-2012 | 12:16 PM
  #2377
Tech Prophet
From Brent Setup sheet:
To Use Front Hexes -> AE Front Hex Spindles (#9880), AC SC10 Axles (#9881), AE Buggy Rear Hexes (#9890), JC Low Profile Wheel Nut.
Old 10-24-2012 | 12:26 PM
  #2378
From: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Is there anyway T4.1 wheels can be shared with a 22T?
Either direction.. I'd like to get both cars to use the same wheels front and back.
lagcisco is offline
Old 10-24-2012 | 12:29 PM
  #2379
I'd your bashing I suppose so but not if racing. The oddest is different no matter what hex package you use
Old 10-24-2012 | 12:35 PM
  #2380
aeRayls's Avatar
Rear
For JC wheels you'll need an sc10 rear hex for the rear!!!
Front
For JC wheels in front with JC axles you'll need sc10 rear hex!!!
For JC wheels in front with ae axles you'll need B4 rear hex!!!
aeRayls is offline
Old 10-24-2012 | 12:36 PM
  #2381
Tech Prophet
Rear
Front
I am beginning to think you have a rear fetish, lol. but yes, I agree on your assessment.
Old 10-24-2012 | 12:45 PM
  #2382
Originally Posted by nitro0619
Anyone tried the new PL scrubs tires yet?
Been running the Scrubs front /Suburbs rear in MC compound on indoor clay and works great for me.
jamr1130 is offline
Old 10-24-2012 | 12:52 PM
  #2383
What's the advantage of the hex conversion? Just ability to rotate tires?
Had nothing but troubles when I ran either the Proline or JC hexes on my SC10 2wd when I had it. No issues up front but had issues in the rear. Couldn't tighten down the rear lock nuts very tight as it would cause binding. But leaving it loose would cause the wheel to come off. I tried axle shims but no help. Went back to pins and never any issues. That's why I haven't converted my B4.1 or T4.1. Just my experience that's all.
jamr1130 is offline
Old 10-24-2012 | 12:59 PM
  #2384
Rear
Front
So it looks like it depends on the front axles you will be using. You will be able to use either wheel.
AE Axles - B4 Rear Hex
JC Axles - SC10 Rear Hex
What about the rear Hexes?
Old 10-24-2012 | 03:23 PM
  #2385
Any thoughts if the scrubs would work good on the rear too? I wanna try some jc pressure points on the rear as well
