RC10B4.1 FT/WC
Old 10-15-2012 | 09:12 PM
  #22366
bilster44's Avatar
Originally Posted by BIGSKI15
Man, did I hack my front shock tower trying to notch it out for the big bores. I like my stuff looking new so I won't be running that tower, lol. Luckily I have a spare tower but I'm going to get a smaller attachment because the grinding attachment radius was much bigger than the ae video showed.
My rear big bores will be in on wednesday but I want the front to be completed by then.
Also, the track I go to everyone runs slicks, which I made out of my hot bodies pink tires with stock foam. A guy there said the tires felt soft and that I should've used closed cell. Would traction be that much better with the firmer closed cell foams?
Is a frogs ass water tight? It will be a night and day difference.
bilster44 is offline
Old 10-15-2012 | 09:38 PM
  #22367
Tyler Keel's Avatar
Originally Posted by Bob Barry
AHHHHHMMMMGGGG THE BLASPHEMY
this is exactly why I'm not rushing to grab my shocks. I'll get em... just have other stuff to get first
Doesn't seem to be hurting the AE cars if you ask me.
Tyler Keel is offline
  #22368
Matt Trimmings's Avatar
Originally Posted by soup99
Just wanted to make sure this is correct, I had nothing in my rear wheel hex packaging that told me to remove the stock blue cone washer before putting the rear hex on?
Which hexes did you buy...that is correct, with hexes all you use is the pin and the hex. The washer comes off.
Matt Trimmings is offline
Old 10-15-2012 | 09:49 PM
  #22369
Im currently running the shave brace and C hub. Our new track is pretty loose I want to try the "A" hub, Do I have to replace the shave brace or can I just add a spacer to get the same geometry?
Thanks,
Rocky
Theroc is offline
Old 10-15-2012 | 09:53 PM
  #22370
Thanks,
Rocky
You can add washers but it may put more stress on the ball stud and depending on the length of your ball stud could cause it to pull out from the u brace in a crash. I would put an un shaved u brace back in.
Old 10-15-2012 | 09:54 PM
  #22371
Wild Cherry's Avatar
Originally Posted by MikeFriery
none of the AE guys do.
Every one of our Team driver's use the bleeder seal's on their BB.....
Wild Cherry is offline
Old 10-15-2012 | 09:57 PM
  #22372
none of the fast AE guys do.
fixed...
Old 10-15-2012 | 10:02 PM
  #22373
Originally Posted by Matt Trimmings
fixed...
bet its leaks
Old 10-15-2012 | 10:05 PM
  #22374
naa, it's a nice package. My comments are more geared towards the fact that the BB springs are good on the V2 shocks, not that the AE BB are bad. Like I said, I will be getting the BB..... Just not rushing as I have other things to buy first.
Bob Barry is offline
Old 10-15-2012 | 10:07 PM
  #22375
CraigMBA's Avatar
May not be helping them as much a possible either.
I'd sure like an oportunity to get rid of my V1 shocks for V2s on my SC10....
CraigMBA is offline
Old 10-15-2012 | 10:19 PM
  #22376
ilanstylz's Avatar
I'm going to be putting up some v2 shocks from a t4.1 with big bore spring conversion for sell pretty soon if interested
ilanstylz is offline
Old 10-15-2012 | 10:22 PM
  #22377
It is so nice to be back in this thread!
Damon_English is offline
Old 10-15-2012 | 10:40 PM
  #22378
suprdave's Avatar
Thanks,
Rocky
Hey...you belong in the Kyosho thread
suprdave is offline
Old 10-15-2012 | 10:43 PM
  #22379
Originally Posted by NitroLuver
I have a question about shocks, what exactly is pack and how can I change the amount a shock may have?
anybody?
NitroLuver is offline
Old 10-15-2012 | 10:49 PM
  #22380
anybody?
Pack is the initial force its take to move the shock piston as it moves inside the shock body..
More pack is good for landing's on big jumps & bumps .
Less pack is good for more traction .
More pack is achieved by using a smaller piston hole
Less pack with larger piston holes
