The Speed Passion Thread >
Like Tree57Likes
Old 10-14-2012 | 09:07 AM
  #10321
JoeyE's Avatar
Originally Posted by blade072
i bought mine knowing that it was already good to go in mod right away......but not knowing that the hybrid stock software was still to come..but its all good as it was so cheap with the lcd box included and its so easy to update anyway
Thanks blade072.
JoeyE is online now
Old 10-14-2012 | 11:37 AM
  #10322
Marcos.J's Avatar
Super Moderator
Originally Posted by JoeyE
Thanks Marcos.
You are welcome.
I came with this set up for 10.5 should worked very well with the 13.5 but didn't get to try it ran out of tires to try the 17.5 lol.
Don't know if this will be the final version but it has great power with the 10.5, my car was actually lifting the front wheels of the ground a couple of times.
Marcos.J is offline
Old 10-14-2012 | 11:40 AM
  #10323
Marcos.J's Avatar
Super Moderator
I didn't get to try different sensor boards I tested them with the stock sensor board.
Marcos.J is offline
Old 10-14-2012 | 01:08 PM
  #10324
got the gt 2.0.bad switch from the box.1 month+ finally used switch from cirtix(support here in ill. so good)wired it in now switch doesnt work at all and powers up only when i hold the setup button down.any ideas
atmeearacing is offline
Old 10-14-2012 | 06:14 PM
  #10325
So right now my Rev Pro out of the box cannot run 4T motors?
...because there is no software for it?
You should have no problem running a 4.5T motor with your Revention Pro.
Originally Posted by Ritchie T
Quick question, can i run the +40 sensor board with a 13.5 MMM ?
Yes. Whatever the class you are running just keep an eye on your motor temperature.
Just to clarify.
You are saying the switch that was included with your GT 2.0 was bad when it was new? Then you installed a on/off switch you took from a Cirtix you had onto the GT 2.0?
SP Tech is offline
Old 10-14-2012 | 08:10 PM
  #10326
i bought it off a guy who won it in the raffle at the roar nationals,so theres no receipt. ive been unable to get help locally so i though i would try the switch from my blown cirtix
Old 10-15-2012 | 08:19 AM
  #10327
Please give our office a call and we will take care of your swtich...Phone 1-888-928-1328.
Solara is offline
Old 10-15-2012 | 09:42 AM
  #10328
anyone used a GT2.0 pro in a WGT 2S lipo and a 17.5 motor that care to share a set up ???
i have the feeling i can either have good torque or good top speed but not both
Thanks Phil
sidecarphil1 is offline
Old 10-15-2012 | 10:31 AM
  #10329
RacinJ's Avatar
Any updates on when the Reventon EX Pro will be available?
RacinJ is offline
Old 10-15-2012 | 10:36 AM
  #10330
Nothing yet....
Solara is offline
Old 10-15-2012 | 11:23 AM
  #10331
And is there any news on how the testing went with the software that'll support 13.5-21.5?
RSCosworth is offline
Old 10-15-2012 | 11:58 AM
  #10332
As above...
Mi4cxl is offline
Old 10-15-2012 | 05:54 PM
  #10333
Originally Posted by or8ital
When will the black reventon pro be back in stock in US?
+1
76Trans Am is offline
Old 10-15-2012 | 06:58 PM
  #10334
Timbo99's Avatar
+1
Timbo99 is offline
Old 10-16-2012 | 08:01 AM
  #10335
JoeyE's Avatar
What USB cable do you need/use for the computer fir the esc?
JoeyE is online now
