RC10B4.1 FT/WC
I have and i run plenty of weight in the front of ky car. Look a few post up. If it causes.the.car to turn more on exit then it is still "creating steering" just at a different part of the turn. I this maybe you should have used less agressive in your statement based on you explination.
not aggressive at all
Suggest to try 2 oz's on the nose and drive a few laps & compare ....
I ran my car with the Big Bores today again at WCRC. Ended up running white rear and green front springs. Car was dialed but I drive poorly and finished 4th in the Main. I had to rebuild my transmission today and replace the bearings and idler gear as a couple of the stock bearings fell apart and the idler gear was badly worn...the car is now super quiet!
Have any of you guys tried the Epic D3.5 17.5 in ur cars? My buddy loaned me his brand new one to try out.
JG
JG
I used my shock piston drills to drill a small hole. Screw the bleeder screw in and trim around the screw head. Cheap, easy and quick fix...or use nothing at all. Guys have been running it with nothing and say they don't leak.
JG
JG
The track is small (40x70) and I am geared at 75/33 with full timing.
This setup is very good with great pull out of the corner and plenty top end.
Dayton
What are you reading that is negative. All the posts that I read are people saying how much better their car ran with them. I did not see anyone that did not like the handling
your thoughts ?
