Like Tree195Likes
Novarossi engines thread
Old 10-12-2012 | 03:46 AM
  #4456
Originally Posted by Roelof
Before the coated pistons there were a lot of issues with damaged pistons at the exhaust port, they looked like they had to less lubrication in conbination with a tight pinch and so the surface of the piston showed as it was rubbed.
The coating was a some kind of DLC which creates a very low friction surface. But after running in the part where it touched the sleeve most had no coating anymore. Probably they have done it to give it a smoother run-in for not damaging the piston.
In the real automotive industry (as I was tod for sure with Mercedes) this is also done a lot on the crankpins.
Oh ok. I see. Which one would you chose over the other? Flash or keep on?
Also, out of the 9886, 2052, 2015, and 2006 pipes which has the most top end?
howard85may is offline
Old 10-12-2012 | 04:47 AM
  #4457
If you have an unlimited budged go for the latest top model. If you are just a good or less driver (and to be honest, most serious drivers know what to choose) I would go for the rocksolid 35-plus-21 with a steel bearing. It is affordable, has goed performance and the steel bearing last longer.
Roelof is offline
Old 10-15-2012 | 04:28 AM
  #4458
Originally Posted by kyosho malaysia
use 97,99 will lost some power
Yesterday i tried using odonnel 77 and after inspecting the plug it did look like the underneath whole is much bigger than the nova one so compression is reduced and it was also felt on the track especially the acceleration.
Am i right or is the clutch slipping a bit
Engine is a 12PT
speed6 is offline
Old 10-17-2012 | 01:15 PM
  #4459
Roelof ........ For the same price wich one :35-plus-21 or Collari edition?
Thanks GHN
ghn-sp is offline
Old 10-17-2012 | 02:01 PM
  #4460
Which Collari? The older Cordoba edition has a smaller crankpin, the Lostallo edition has the 5mm crankpin. The smaller crankpin has some issues......
Roelof is offline
Old 10-17-2012 | 05:16 PM
  #4461
Which Collari?
The Novarossi Collari WC09 or the 35+21 steel?
GHN
ghn-sp is offline
Old 10-18-2012 | 01:51 AM
  #4462
The Collari WC09 has the R7 rod again and som other advantages. So if you can get it for (almost) the same price it is a good choice.
Roelof is offline
Old 10-18-2012 | 05:35 AM
  #4463
Thank you for your help.
GHN
ghn-sp is offline
Old 10-18-2012 | 11:04 AM
  #4464
Engine is a 12PT
i don't think the plug underneath whole will effect the acceleration so much,i mod the turbo button whole wider(compression redused) and the performance better.
kyosho malaysia is offline
Old 10-23-2012 | 07:56 AM
  #4465
What's the best way to break in a keep on .21? Thanks.
Old 10-23-2012 | 08:01 AM
  #4466
Grinder's Avatar
http://murnanmodified.com/breakin.php
Grinder is offline
Old 10-23-2012 | 04:20 PM
  #4467
Originally Posted by Grinder
Step 2, when you say establish a rich idle, do you mean start it at factory settings or lean it on the top or bottom a little?
Step 3, is that continuous 750cc of fuel or heat cycle every tank until 750cc has been run?
Step 4, same question as step three, heat cycle every tank or continuous for 750cc?
Thanks for all your help. You're deffinately an asset to this hobby.
Old 10-24-2012 | 09:42 AM
  #4468
Grinder's Avatar
Rich idle usually means factory settings. Just make the idle where it will not shut off, and some raw fuel is coming out of the exhaust.
No need to heat cycle each tank. In between each 750cc is fine.
Grinder is offline
Old 10-24-2012 | 11:52 AM
  #4469
http://www.youtube.com/watch?v=JT2GQr9UEoM
How's this look? Nothing special, just starting the break in process. Idled through 150cc tank today. Next step tomorrow. So for the next step, should i just leave the needle settings as they are from factory and run it for another 750cc or should i lean it a little? Thanks for the help.
Old 10-25-2012 | 12:28 PM
  #4470
Ok. I'm 600cc into step 3 and have one more tank before I move to the next step.
Question, step 4, should I go ahead and reduce Idle gap to .5mm and tune the low end slight rich so I don't get that pinging sound at the end of a run when I let off? If I don't it will race after a pull through the rpm range because of the big idle gap and rich bottom. I already richened the hsn to get plenty of smoke and lubrication. Thanks.
