Durango DEX210 Thread
#7831
What dont you like about the durango gear diff?
I have been running one since they were available and have not had a single issue.
They take a few runs to break in but after that are great.
It fits better than anything else as it's designed for it.
I can't comment about the losi diff but if you try an associated one it will eventually fail as the diameter of the durango diff is slightly bigger by about .95 of a mm.
This is not much but when you consider the teeth on the gear are less than 1mm tall you have mesh issues from the start - see pic - top gear is Team C ball diff gear but is the exact size of an associated.
We found this out the hard way, the sc10 diff lasted about 2 minutes (MM4 high grip carpet).
I believe the losi is the standard diameter too as per xxx, b4, sc10 etc.
Cheers Matt
Cheers Matt
#7832
hi there
sunday i had a race on dirt track. the bal diff was a disaster on saturday training, so i went sunday with the gear diff and 10 000 oil in it, because the track was very loose. next i will try 15 000 oil in the gear diff.
i have the 8 racing carbon chassis with the stock lengt and the rear 8 racing carbontower in my car. its durable
mihael
mihael
#7834
I dont like thin oil in the gear diff.
The car rotates too fast, if the track is loose.
Thin oil for carpet and thicker on loose track.
I run a 7,5 x11 lrp motor with a hacker tensoric esc.
Mihael
Mihael
#7835
Aluminum front and rear towers...what do u guys think?
http://www.redrc.net/2012/09/rdrp-du...ts/#more-58433
These are the nicest towers I have yet to see on a dex210, do you guys feel it is necessary to replace the stock towers?
Cheers
Cheers
#7836
Cheers
Cheers
I am curious on the weight though the 210 is a bit on the plump side.
#7837
Cheers
Cheers
#7839
Guys...new items from Exotek.
http://www.exotekracing.com/dex210-d...ront-bulkhead/
http://www.exotekracing.com/dex210-d...-servo-mounts/
#7841
wish those exotek rear hubs came in GOLD
#7843
#7845
