RC10B4.1 FT/WC
Old 09-13-2012 | 06:49 PM
  #20401
RED-LINE M03's Avatar
Originally Posted by Matt Trimmings
I'm running shorty's with big bore springs...
In mod or 17.5...?
RED-LINE M03 is offline
Old 09-13-2012 | 06:53 PM
  #20402
rigor's Avatar
Originally Posted by EricJ
Whoops, I was confused there. Shock body length vs. shaft length. It's because the truck shafts and bodies are marked 1.02" on the front and .80" shafts are often nearly impossible to obtain when you break them.
When I was learning to drive 4WD, I quickly learned to stock spare parts that were cheap. Shock shafts are only like $6. This was your day of 4WD fun doesn't come to a screeching halt.
Hopefully AE can make spare big bore shafts available at launch.
rigor is offline
Old 09-13-2012 | 06:54 PM
  #20403
rigor's Avatar
Me as well. I found the car to be better with big bore springs and shorty packs, regardless of stock or mod.
rigor is offline
Old 09-13-2012 | 06:55 PM
  #20404
B.A. Racer's Avatar
Originally Posted by RED-LINE M03
The Reedy 25c 5000 Wolf pack are the same weight as the shorty packs but they are the ful size packs correct....?
Always run the full size Wolfpacks with the big bore spring conversion.
No one is running a shory wolfpack with the big bore conversion correct...?
Thx...
False. The ready wolfpack weighs between a full size pack and a shorty pack. Most shortys weigh around 200-205 grams, the wolfpack weighs 261g and most full size packs weigh around 285-300 depending on the c rating and size of the pack. I ran shorty for a small time before i ran the wolfpack. I love the way the wolfpack feels and im currently selling my shorty! (if anyone wants one ) if you run on a high bite indoor clay track..then you might want to try one..but if you run on a track with even allitle bit of dust or bumps..i wouldnt even think about buying one
B.A. Racer is offline
  #20405
Matt Trimmings's Avatar
In mod or 17.5...?
The way you stated it it shouldn't matter. I use a shorty with 17.5 and 13.5
Matt Trimmings is offline
Old 09-13-2012 | 06:56 PM
  #20406
rigor's Avatar
Originally Posted by aeRayls
You also get all the spring cups because buggy front springs are also truck front springs now. There will only be 2 spring kits to buy!
Can you elaborate on the spring kits ? Will they be sold as "Spring Kits" only, as Avid does now? Or will you be able to pick and choose which springs you want to purchase ?
rigor is offline
Old 09-13-2012 | 07:05 PM
  #20407
Ah that's what I was looking for.
Good info thanks...!!!
Old 09-13-2012 | 07:11 PM
  #20408
Yeah, I keep a pretty sizable stock of them after a couple of those incidents. I even have spare shocks so I can just swap one out and fix the broken one later.
I wouldn't buy them until I had both suitable shock towers and could get some spare shafts. Too risky otherwise.
I probably won't take the plunge until I've exhausted most of my V2 shock parts...
EricJ is offline
Old 09-13-2012 | 07:25 PM
  #20409
Originally Posted by TJMac
Has anyone tried the new AE hex adapters yet?
What are the part numbers for these? The only thing I could find for the B4/B4.1 are the plastic ones #7497.
-Chocula
Chocula is offline
Old 09-13-2012 | 07:47 PM
  #20410
-Chocula
http://www.teamassociated.com/news/l..._Wheel_Hexes_/
Old 09-13-2012 | 08:22 PM
  #20411
ilanstylz's Avatar
Why are people complaining so much about the ae big bores? First it was oh they need to hurry up and come out its taking forever, then you want to complain about the price? To me the price isn't bad at all, the v2 non big bore shocks go for about $80+ for a new set and with the big bores only being about $20 more I think its priced just right but hey that's just me........
ilanstylz is offline
Old 09-13-2012 | 08:24 PM
  #20412
bilster44's Avatar
Originally Posted by 3srcracing
I think spending $110 on shocks to make you just SLIGHTLY faster is crazy.
Well I guess it all comes down to what one can afford or wants to have...Why not have all the the kicks,the new shocks and spend a lot of time practicing? That's my plan and I'm sticking to it.
bilster44 is offline
Old 09-13-2012 | 08:41 PM
  #20413
Wild Cherry's Avatar
If your serious about practice & lap times ?
Your going to want the new Ae BB ......
Wild Cherry is offline
Old 09-13-2012 | 08:47 PM
  #20414
Wildcat1971's Avatar
Tech Prophet
In all honesty, I am going to let you all buy them and tell me if the tower needs to be modified etc. Then I will buy, your all my test subjects, muhaaaa
Wildcat1971 is offline
Old 09-13-2012 | 08:54 PM
  #20415
Heh, "goon". I've never heard that term for it. I thought it was "n00b", "ghetto", or similar. I can't stand running mismatched wheels, either, which is why I'll switch to Mono wheels once I run out of this huge stack of Rulux I have. The nice thing about dish is if they're the same color (white), you can't tell if they're mismatched without looking very closely.
The rumor down here in SoCal is that your car pushes more with Rulux on the front since air passes through them. I believe Tater told me that...
The funny thing is when I see people running mismatched wheels they're almost invariably running the Rulux wheels in front and dish in the rear, which should be the worst possible option.
My only issues with them are the lack of hexes and the fact they're a bit on the soft side, so they break easily in use and/or deform when stored. I actually like how they look and find the spokes a handy wheel speed indicator.
You believe Tater? j/k.....
jpcopeland1 is offline
