RC10B4.1 FT/WC
253-565-1935
but
for those who have AVID ?Just maybe better to keep ....
My friend is running a 7.5 LRP geared at 20/78, tekin rs with 20 boost, no turbo, 80 current limiter, no drag, no push, and stock throttle curve.... Try that out and adjust from there prim.........
Wildcat -- Go back to the AE Pistons (what the manual states), 24mm Ride Height F/R, Switch to JC Groovy / Double Dee (green) tires, take the C Hub off and go back to the A with 1 washer on a standard brace, take the weight out of the front triangles, add at least 1 washer under the front ball stud, rear lower shock inside position. I also only tried the losi springs on my B4 at hobbytown once and went back to the regular brown/green setup. Never liked how they felt, switched to Kyosho springs (pink F/white R) and they were better, now i run Avid (Red F/Yellow R).
Oh and dont come out of the corner hard onto the straight. you need to roll onto the throttle, especially at CV.
Does anyone have the spacing recorded (or can caliper them) from the hinge pin hole to the camber link mounts for each of the A,B,C hubs? I am running yokomo and I don;t know that the relationship is between them and the real lengths would be just for tuning.
Thanks in advanced
Thanks in advanced
