RC10B4.1 FT/WC
Old 08-11-2012 | 10:01 AM
  #18361
Wild Cherry's Avatar
Originally Posted by zipperfoot
I like to check in on the forums to get pertinent information, but lately it all seems to be nothing but complaining about things that may or may not even affect the performance of the B4.1 buggy...
Hey !
Thanks for checking in , don't be long as you most likely miss something, not including complaints of course .
Ryan , Don't see Ae rep cus time after time a bunch of keyboard commando's attack when ever they come to help make this thread more useful & fun ...
So ?
Your all stuck with me ....
Talk about hurting
Printed your set-up if you still need ..
Wild Cherry is offline
Old 08-11-2012 | 10:13 AM
  #18362
Hey !
So ?
Talk about hurting
Hurting is right!
PFKAOG is offline
Old 08-11-2012 | 10:14 AM
  #18363
Yeah I'm bad ....
Mike C
Nice work with the hub ...
That's how to do it right ...
Old 08-11-2012 | 11:57 AM
  #18364
nismomike's Avatar
Originally Posted by bds81175
About the only problem I had with the aluminum U brace is I managed to snap off a ball stud flush with the surface. Its kind of a buggar to get back out. It was flush with the bottom and flush with the top and thread locked in place. Handling wise, I think it was more sensitive to the roll center adjustment I make.
Whenever I run aluminum, such as the U-brace and my STRC knuckles, I use a ball stud that threads all the way out the other side just far enough to grab it with needle nose pliers if the stud ever breaks off flush.
nismomike is offline
Old 08-11-2012 | 12:05 PM
  #18365
ryanpatrickgore's Avatar
Wc exactly what I ment. You explained it better. Haha
Yes please I would love the setup!!
ryanpatrickgore is offline
Old 08-11-2012 | 12:10 PM
  #18366
PM me your E-mail address
Proof !
Our Rc10 B4.1 thread on RcTech ?
Your best place for useful info & set-up advise ..........
Old 08-11-2012 | 01:24 PM
  #18367
rider313's Avatar
Any of you guys using DE racing rear wheels? I have a bunch left over from my 22,the package says 22/B4.1 with hex. However the hole seams small around the wheel nut. I actully don't have a wrench that fits in there for the AE wheel nut.
rider313 is offline
Old 08-11-2012 | 01:35 PM
  #18368
Tradin Paint's Avatar
Yes, I use them. The hole is even smaller on the front wheels. I had to buy the green Asscoiated nut driver as this was the only one the I found to fit
Tradin Paint is offline
Old 08-11-2012 | 03:27 PM
  #18369
Wildcat1971's Avatar
Tech Prophet
+1 for grub screw. My drilling abilities need work, but I put 2 in each hub. About 60% of the slop went away. I suggest a fine tipped punch to indent for drilling or it wonders. You might have to drill a little into the far side of the pin hole for the tap to be able to go far enough in to thread all the way. A dab of blue locktite on the set screws and dont. I did go buy a drill press vice for $16 do hold the hubs still though. Al said about $30 in parts to fix my $30 hubs, lol
Wildcat1971 is offline
Old 08-11-2012 | 04:13 PM
  #18370
Odin544's Avatar
Just need a bottom tap.
Odin544 is offline
Old 08-11-2012 | 04:18 PM
  #18371
Tech Prophet
All I could find was the dubro
Old 08-11-2012 | 04:33 PM
  #18372
Odin544's Avatar
What you can do is drill all your holes and tap them as deep as you can with the tap. Then take a grinder and grind the end of the tap down a little. So there is just a little bit of taper left. Then finish tapping them.
I know you are already done with yours. But for anyone else that needs to do it.
Odin544 is offline
Old 08-11-2012 | 07:00 PM
  #18373
I have the same problem with the DE wheels for my T4.1. The only wrench I have that fits is the plastic AE one that comes with the kit. Pretty disappointing.
ufoDziner is offline
Old 08-11-2012 | 07:16 PM
  #18374
bds81175's Avatar
Moderator
Dynamite wrenches fit the DE wheels.
bds81175 is offline
Old 08-11-2012 | 07:22 PM
  #18375
dmatter's Avatar
I just used a steel 4-40 screw with a 3/32 head and some bushing oil to get the hole threaded further. My old bolink tap was not cutting far enough for my liking due to the taper. I did one screw in the center and it cut the slop in half. For the sloppy bearing holes I use blue painters tape. I think the car works way better and runs quiter with these mods. Oh yea....No more toe out on the rear lol.
dmatter is offline
