RC10B4.1 FT/WC
Thanks for checking in , don't be long as you most likely miss something, not including complaints of course .
Ryan , Don't see Ae rep cus time after time a bunch of keyboard commando's attack when ever they come to help make this thread more useful & fun ...
So ?
Your all stuck with me ....
Talk about hurting
Printed your set-up if you still need ..
Hey !
So ?
Talk about hurting
So ?
Talk about hurting
About the only problem I had with the aluminum U brace is I managed to snap off a ball stud flush with the surface. Its kind of a buggar to get back out. It was flush with the bottom and flush with the top and thread locked in place. Handling wise, I think it was more sensitive to the roll center adjustment I make.
PM me your E-mail address
Proof !
Our Rc10 B4.1 thread on RcTech ?
Your best place for useful info & set-up advise ..........
Any of you guys using DE racing rear wheels? I have a bunch left over from my 22,the package says 22/B4.1 with hex. However the hole seams small around the wheel nut. I actully don't have a wrench that fits in there for the AE wheel nut.
Yes, I use them. The hole is even smaller on the front wheels. I had to buy the green Asscoiated nut driver as this was the only one the I found to fit
+1 for grub screw. My drilling abilities need work, but I put 2 in each hub. About 60% of the slop went away. I suggest a fine tipped punch to indent for drilling or it wonders. You might have to drill a little into the far side of the pin hole for the tap to be able to go far enough in to thread all the way. A dab of blue locktite on the set screws and dont. I did go buy a drill press vice for $16 do hold the hubs still though. Al said about $30 in parts to fix my $30 hubs, lol
What you can do is drill all your holes and tap them as deep as you can with the tap. Then take a grinder and grind the end of the tap down a little. So there is just a little bit of taper left. Then finish tapping them.
I know you are already done with yours. But for anyone else that needs to do it.
I have the same problem with the DE wheels for my T4.1. The only wrench I have that fits is the plastic AE one that comes with the kit. Pretty disappointing.
