Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 08-09-2012, 10:42 AM
  #316
skrichter's Avatar
Trader Rating: 13 (100%+)
Originally Posted by lbckevin
Tebo looked good in the RB6 tonight at West Coast....but the win went to Cody Turner in the RB5 WC +13.... still plenty of time to work on setup ...
Does anyone make the +13 chassis for a small fee? I know there was a guy who made the +8 for AE before they were released (who did a great job).
skrichter is offline
Old 08-09-2012, 10:50 AM
  #317
toast.'s Avatar
Trader Rating: 14 (100%+)
I'd be interested in this also.
toast. is offline
Old 08-09-2012, 11:12 AM
  #318
Registered User
Originally Posted by Rfury
You should make and post the list. That way we can all review it and make sure nothing is missing.
All new parts are numbered UM700 to UM729. (Body not included)
Depending on what your set up is (mid ship or rear mount) you can take out some parts.
I am not going down to the nuts and bolts.
oosh123 is offline
Old 08-09-2012, 11:36 AM
  #319
Yeah, I knew that much.
I just thought you already had the list on hand as you had priced everything already.
I may look into it later.
Rfury is offline
Old 08-09-2012, 12:13 PM
  #320
Here is the list I came up with. It is quite long.
Basically every part number from UM700-UM728 is required for rear motor RB6 except...
UM720
UM722 - UM726
These parts are for the mid-motor and would replace the following rear motor specific parts if you wanted a mid-motor car instead....
UM705
UM706
UM708
I have no idea on prices. I am not going to look that part up.
The body is UMB03 and the wing is UM727. The decals if you care are UMD02. The part number UM719 is the 1 piece shock caps. They are not needed really, but would be required to have a "complete" RB6
You will also need UM561. These are the rear outer hinge pins for the RB6 and are from the RT5/SC-R.
Rfury is offline
Old 08-09-2012, 12:33 PM
  #321
Registered User
UM719
UM720
UM722 - UM726
UM705
UM706
UM708
UM719 is the one piece aluminum shock cap. you will need it for both version of the buggy.
oosh123 is offline
Old 08-09-2012, 12:35 PM
  #322
Thanks. I missed that. I will correct the original post.
Rfury is offline
Old 08-09-2012, 01:13 PM
  #323
Registered User
ohh.. the rb6 kit comes with the white slipper sheet (UM516) instead of the Red one (UM571)
And not the vented slipper disk too.
oosh123 is offline
Old 08-09-2012, 02:55 PM
  #324
toast.'s Avatar
delete
toast. is offline
Old 08-09-2012, 05:02 PM
  #325
savageboy69's Avatar
Trader Rating: 93 (100%+)
savageboy69 is offline
Old 08-09-2012, 05:08 PM
  #326
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
There is a pic on Kyosho's facebook page of him working on the car.
Posvar is offline
Old 08-09-2012, 05:15 PM
  #327
Moderator
Posvar's Avatar
Posvar is offline
Old 08-09-2012, 05:22 PM
  #328
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Just curious about the long radio antenna tube. Are KO's antenna that long?
Kraig is offline
Old 08-09-2012, 05:33 PM
  #329
Car is not available yet but editable setup sheet is, check petit
Arn0 is offline
Old 08-09-2012, 05:37 PM
  #330
mdowney's Avatar
Trader Rating: 21 (100%+)
Well, you don't "need" the one piece alu shock cap. If you're converting an RB5 you can run the shocks as-is. This might be a good place to save a few bucks as alu parts are usually pricey.
No. My best guess is that guys run long antenna tubes so they can see their cars better when they're either far away, behind something, or in a ditch and can't be seen from the drivers' stand. That's why I do it, anyway.
mdowney is offline
