Team Associated SC8 Setup and Tips >
Old 08-01-2012 | 11:22 PM
  #766
Originally Posted by t3gt
I've looked through the manuals, Comparing what's new and old, and I have a list for the SC8.2 and RC8.2 upgrades....I'm hoping this is everything, but I don't know for sure until I do the upgrade myself.....If anyone does it before me, let me know if I'm missing anything.....Here we go:
SC8.2e Upgrade Parts
89472 - Front Bulkhead Spacer
89558 - Caster Blocks
89586 - RC8.2e RTR Shock Tower (front)
89587 - RC8.2e RTR Shock Tower (rear)
89549 - Front Upper Arm
89579 - SC8.2e Body Mounts (front)
89579 - SC8.2e Body Mounts (rear)
89550 - RC8.2 Front Arms
89551 - RC8.2 Rear Arms
89530 - RC8.2 Front Sway Bar Kit
89531 - RC8.2 Rear Sway Bar Kit
**For some reason both body mounts have the same number in the manual
RC8.2e Upgrade Parts (from an RC8B)
or 89538 - RC8.2 Front Shock Tower (aluminum)
or 89539 - RC8.2 Rear Shock Tower (aluminum)
you forgot the different shocks there longer
Mindcrimes is offline
Old 08-02-2012 | 05:32 AM
  #767
t3gt's Avatar
Well, The SC8.2 shocks and springs are the same as the original because they use the RTR towers.....the RC8.2 shock shafts are 2mm shorter as well as the springs for the FT towers, but the RTR towers have the same old shocks like the SC8.2 has.
I didn't put the Shaft and Spring numbers in for the RC8.2 upgrades....I'll add them a little later.....
t3gt is offline
Old 08-02-2012 | 05:45 AM
  #768
IMVHO it's probably a legitimate question to ask - what benefits are you going to get from converting all that stuff to RC8.2 "specs"? Take a look at the RC8.2 thread - all anybody talks about is changing the RC8.2 into something else.. Lots of people talk about lack of traction out of the box, and all in all it seems that for many people the 8.2 takes some modding to get it where people like it..
The SC8, with that big heavy cage and enormous body, is never going to be as nimble and quick as any buggy. IMO the SC8 can be enhanced just like you would have modded an old RC8 or RC8B. Big-bore shocks, and maybe some other tweaks, like alu caster blocks or whatever.. But really, I kind of doubt the wisdom of going all out and modding to 8.2 specs.. If anything just wait til the 8.2 SC8 version comes out and buy one.. All those parts would add up I would think.., and you'd be much better off investing in engine, pipe, clutch, tires, a second engine, whatever... For racing, knowing basic setup (something I don't know..) is far more important than having the newest stuff(that I do know..) But hey, if you're dying for a project, go for it..
Herrsavage is offline
Old 08-02-2012 | 10:51 AM
  #769
Stock sc8 has has no shock adjustments so u need big bores and aftermarket towers to perform better
Old 08-02-2012 | 11:40 AM
  #770
t3gt's Avatar
I'm just wanting to upgrade the suspension parts only, the other stuff won't benefit the SC8 anyway.....Right now it has the geometry of the RC8B which is better for more tight tracks and concentrating on side to side roll center action.....the RC8.2 geometry is more of a jumping, BMX style track setup, like the tracks they've been racing the last couple years....it's more like the original RC8 geometry except more updated and slightly Lower COG....
I think the newer .2 jumping setup could benefit the SC8, but the lower COG would make no difference at all....So I'll use the RTR towers with the older BB Shocks
The parts add up to no more than $150 from what I can see.....so it's not a bad route.....but if you don't have an SC8 yet, just go for the SC8.2.....
t3gt is offline
Old 08-02-2012 | 01:25 PM
  #771
So guys i just got an lrp.28. U think I should run an 18t clutch bell with stock spir. Looking for lowend
Old 08-02-2012 | 01:35 PM
  #772
If you want low end, go with a lower CB - 17 or even 16 if you really want to drift.. I have an 18T CB, but with an LRP ZR.30, and it has good bottom.. Depends how much bottom you want.. I say start with 17..
Old 08-03-2012 | 02:38 PM
  #773
well i put on rc8 bigbores on. what spring should i run and shock oil curently its 35/60 the front bottoms out bad even from like a foot but the rear is stiff from 4 feet high no bottom out. should i set the front as the rear. the rear has the brown springs and the front has chrome.
Old 08-03-2012 | 02:40 PM
  #774
PMAZ7's Avatar
You setup is completely ass backwards from mine.
PMAZ7 is offline
Old 08-03-2012 | 03:03 PM
  #775
i just pulled the shocks of my rc8 and my rc8 ran perfect with it just seeing what u guys recommend with the bigger shocks
Old 08-03-2012 | 03:04 PM
  #776
PMAZ7's Avatar
I'm 45 oil all around, bronze up front and silver in the rear. I'm also running the heavier t-bone front bumper too.
Most likely going to go down to 40 in the rear.
PMAZ7 is offline
Old 08-03-2012 | 03:22 PM
  #777
was told if u go tbone u should get both bumpers cause it make the car jump bad if u only have the front ones
Old 08-03-2012 | 03:49 PM
  #778
PMAZ7's Avatar
That's probably true but you can also compensate for it, as I have.
PMAZ7 is offline
Old 08-03-2012 | 10:06 PM
  #779
No need for 60 at all.. Try 40/40 - with stock springs.. Brown are really hard I think..
Really hard shocks only makes sense if it's for like onroad, and it's massively hot outside..
Also, it really depends what you want to do.. For the street, maybe 45 even.. Jumping.. - a bit less.. A track, less again.. "Bottoming out" on the street might mean it would soak up bumps on a track better.. All about what you want to do with it.. 35 or 40 IMO are generally good all-round weights..
Try 40 all around, with 1-2cm preload on the springs, with silver springs or whatever the original ones are..
Old 08-04-2012 | 12:37 AM
  #780
i have big bores on it from the rc8 so there adjustables without preloads
