Like Tree2991Likes
1/12 forum
Old 07-24-2012 | 07:48 PM
  #38086
silvalis's Avatar
After a few trial and errors, I went about 54mm on my x12 13.5 boost
silvalis is offline
Old 07-24-2012 | 10:12 PM
  #38087
Chris, what body is that?
RoyU is offline
Old 07-24-2012 | 10:36 PM
  #38088
silvalis's Avatar
What are the pros and cons of Yokomos front/rear shock setup compared to typical Link tubes which are all the rage?
silvalis is offline
Old 07-25-2012 | 12:00 AM
  #38089
Manfredo's Avatar
Where can I get that Steering knuckle that's on Naoto's car and what Servo is he using?
Manfredo is offline
Old 07-25-2012 | 09:01 AM
  #38090
Aaronk99's Avatar
Hey guys how should i treat my front tires with additive would it be front inner half or full treatment thanks,aaron
Aaronk99 is offline
Old 07-25-2012 | 09:52 AM
  #38091
DesertRat's Avatar
For all of those who haven't seen CRC's most recent sharp object prototype...
http://events.redrc.net/wp-content/g...arpercrc-4.jpg
DesertRat is online now
Old 07-25-2012 | 10:28 AM
  #38092
RedBullFiXX's Avatar
Most treat the inside
Mountain of info HERE for the new to 12th scale racers
RedBullFiXX is offline
Old 07-25-2012 | 01:31 PM
  #38093
chris moore's Avatar
Dont know for sure, I did this one and an old Olds areo-tech body for a customer. It is an older body tho, back before the use of overspray film.
chris moore is offline
Old 07-25-2012 | 05:08 PM
  #38094
LonnyJ1950's Avatar
It varies from track to track, sometimes from heat to heat. Start with about 1/4 to 1/3 inside and add or subtract depending on how the car handles.
LonnyJ1950 is offline
Old 07-25-2012 | 07:21 PM
  #38095
Aaronk99's Avatar
Thank you for awnsering
Aaronk99 is offline
Old 07-25-2012 | 07:22 PM
  #38096
Aaronk99's Avatar
Also thanks to you for your awnser
Aaronk99 is offline
Old 07-26-2012 | 01:40 PM
  #38097
Applesauce's Avatar
Hey All,
What are you all running for servos?
Applesauce is offline
Old 07-26-2012 | 02:24 PM
  #38098
Originally Posted by Applesauce
Hey All,
I've been running the Futaba S9650 for several yrs now, for me its a great blend of affordablity and performance. There are better/more expensive servos you can use.
Old 07-26-2012 | 02:27 PM
  #38099
wingracer's Avatar
Futaba 9650 or that JR I can never remember the number for are the best out there IMO. KO also makes a nice one but I have never used it so can't compare. Most everything else is junk.
wingracer is offline
Old 07-26-2012 | 03:32 PM
  #38100
M7H's Avatar
M7H
Don't forget about the Savox SH-1357, once you have used it you will never look back.....
M7H is offline
