RC10B4.1 FT/WC
Old 07-15-2012 | 01:39 AM
  #16606
Thanks, will put some glue onto the CVA pin retainer.
Looking at the manual, it has a warning on the CBA page, what does it mean don't use CVA pin retainer if using set 4-40 screw? Where does that come into the build??
Also what oils you guys using for front and rear shocks? and how much rebound?
Attached Thumbnails RC10B4.1 FT/WC-screen-shot-2012-07-15-5.52.49-pm.png
Vinno is offline
Old 07-15-2012 | 01:41 AM
  #16607
CraigMBA's Avatar
I'm confused by that too. Is this an either/or deal?
CraigMBA is offline
Old 07-15-2012 | 03:19 AM
  #16608
"dab of CA glue on the CVA retainer shim"
What is a CVA retainer shim? Part *? Something?
shagnat is offline
Old 07-15-2012 | 03:48 AM
  #16609
LOSI123's Avatar
Wild Cherry,
Can you tell me if any of the Losi Compounds in tires are close to a JC Greeen, or Blue?
Was wanting to pick up some Bk Bars and Taper Pins but Ive never had Losi Tires before
LOSI123 is offline
Old 07-15-2012 | 06:32 AM
  #16610
losi red compound are the closest to the other brands
mel_russ615 is offline
Old 07-15-2012 | 08:59 AM
  #16611
TJMac's Avatar
On the diagram Vinno posted its 7996. If you run the set screw you don't need the retainer. I run both, just because.
TJMac is offline
Old 07-15-2012 | 09:04 AM
  #16612
nismomike's Avatar
[QUOTE=Wild Cherry;10975105]
Originally Posted by CraigMBA
Are we going to do this again?
It was a brand new kit out of the box.[/B]. All of it.
And guess what? They were new, and noisy too.
Do you get it that this was a brand new kit
Craig ?
Just send me your ride , cus its brand new and nice & tight ..
Promise to send you mind , its not so new, not so tight , but way fast & also very quite.....
Just ask anyone from around here ...
apologies bro
can't take advise using sandpaper on the top shaft gear ...
BTW
No! U don't get the PINK ProLine BULL DOG
Is that a shortened SC10 CF battery strap in there?
nismomike is offline
Old 07-15-2012 | 09:21 AM
  #16613
Wild Cherry's Avatar
Originally Posted by LOSI123
Wild Cherry,
losi , awesome question
Sorry, have limited experience with most of the JConcept compounds cept Gold.
believe JC green is similar to Red Losi
nismomike
U got a SHARP EYE
yes, a carbon Sc10 battery strap in there ....
Wild Cherry is offline
Old 07-15-2012 | 09:25 AM
  #16614
Wildcat1971's Avatar
Tech Prophet
nismomike
U got a SHARP EYE
Does green hold up better than red?
Wildcat1971 is offline
Old 07-15-2012 | 09:28 AM
  #16615
All depends on how abrasive the track conditions are ...
wet clay tire wear can be quite low compared to dry
Old 07-15-2012 | 10:28 AM
  #16616
idrummerboy13's Avatar
Green is for lower bite or dryer conditions. blue is opp. pink works best in damp conditions. sweep tendroid is also really good. In silver they have the corner speed and grip everyone likes. pl scrub front is dialed also.
idrummerboy13 is offline
Old 07-15-2012 | 11:19 AM
  #16617
http://www.teamassociated.com/pdf/ca...Reedy_Race.pdf
what are the losi 56 pistons referred to in this setup?
these?
http://www.amainhobbies.com/product_...stons-56-Red-4
Dillon71 is offline
  #16618
Rob Phillips's Avatar
AE train now boarding!!!!
I've been running a TLR22 since returning from a break in racing. After being the subject of much ridicule from my friends, I decided to sell one of my Losi's and give the B4.1WC a try. Hopefully, I will not be let down. I haven't wheeled an AE buggy since the original RC-10.
...and just out of curiosity, why are a lot of you guys running MIP axles? Reminds me of the old days! lol
Rob Phillips is offline
Old 07-15-2012 | 11:22 AM
  #16619
Originally Posted by Dillon71
Those are the red losi pistons that were used on pretty much all the XXX line of cars (and others).
Oops, didn't see your second link...yep that's them.
Old 07-15-2012 | 11:43 AM
  #16620
I want to take advantage of the 20% off trade in deal with Savox, so can anyone suggest a good Saox servo to use with this buggy?
Thinking of a 1258TG...thoughts?
