SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 07-08-2012 | 09:22 PM
  #466
bergie33's Avatar
THANKS GUYS!!!
It was even cheaper...checked the connections on the sensor wire, reconnected, works great! That was my first battle with sensor issues, so I had no clue how they acted.
bergie33 is offline
Old 07-10-2012 | 12:16 PM
  #467
Default sc10 rear toe block
Does anyone know what the original sc10 rear toe block was? As in what degree was it?
Rawwolf is offline
Old 07-10-2012 | 12:28 PM
  #468
J_Bone's Avatar
3.5°
J_Bone is offline
Old 07-10-2012 | 01:57 PM
  #469
RCNurse's Avatar
Just wondering, has anyone heard or seen anything about converting an SC10 to a SC Buggy? There were a few raced this past weekend at my local track, and they looked pretty cool, and fun! I don't want a Losi or plastic shocjed kyosho...
RCNurse is offline
Old 07-10-2012 | 02:38 PM
  #470
Cloaked's Avatar
Get a B4.1 chassis and a Kyosho/Losi body and you should be right to go.
Hell you probably dont even need the Chassis.
Cloaked is offline
Old 07-10-2012 | 03:57 PM
  #471
Riv2SC10's Avatar
From: In the Greater Ladysmith, WI metropolitan area
If you are asking about he RTR SC10, both of mine came with 2.5° blocks.
Riv2SC10 is offline
Old 07-10-2012 | 04:29 PM
  #472
19_mustang_96's Avatar
Im going over my current setup. Has anyone used the springs that come with FTSC10 kit?
19_mustang_96 is offline
Old 07-10-2012 | 10:53 PM
  #473
Yeah I think thats it. It is the part that still comes in the #9818 rear hinge pin mount kit. There are no numbers listed on it like the ones that come with the RS rtr. RS has the 3.5 installed but comes with the 2.5, 3, and the 4 degree blocks. I was hoping it was different from the marked ones for maybe a extra option for tuning. thanks guys for the info.
Rawwolf is offline
Old 07-10-2012 | 11:02 PM
  #474
I have not run the grey rears but for indoor clay I use the red fronts silver rear. Outdoor I use blue front green rear. 30wt oil all around stock pistons 3 fr 1 rr.
Rawwolf is offline
Old 07-11-2012 | 04:51 AM
  #475
Acill's Avatar
I saw a custom cut chassis over in the associated thread at RCshortcourse of one done up very well. He even got professional pictures done and submitted it to Associated for consideration.
Acill is offline
Old 07-11-2012 | 10:21 AM
  #476
mysupratoy94's Avatar
I have a FT Sc10 and heard of a few people switching their FT turnbuckles for the 4x4 ones. Is this possible? Has anyone tried it and what is the gain in doing so?
mysupratoy94 is offline
Old 07-11-2012 | 10:31 AM
  #477
Rysuleod's Avatar
I did it. In theory it's more durable. I ended up taking mine off and going back to the stock just to use the same wrench on both ends. Also the 4x4 ball ends are taller so you have to take that into account when tuning. Since the threaded bit on the ball ends are a larger diameter you end up having to force it into the U-brace and the hub end. The fatter turnbuckles were also close to my non-big bore springs.
My opinion is, unless you are crashing hardcore and having the back end links pop off all the time, I don't think it's worth doing.
Rysuleod is offline
Old 07-11-2012 | 10:45 AM
  #478
Thank you for the info and advice, ill pass on this option.
Old 07-11-2012 | 11:49 AM
  #479
Any new hot setups? I haven't seen anything added on AE's site for a while and I haven't raced in 5 months.
It will be an outdoor track, DD's for Tires all around.
AxiomJacob is offline
Old 07-11-2012 | 11:52 AM
  #480
Acill's Avatar
I just went the Lunsford Ti route for my turnbuckles. They are a lot stronger looking the the stock FT ones mine came with at least. Also Lunsford will replace them free if you bend or break one.
Acill is offline
