SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 06-20-2012 | 08:30 AM
  #286
Originally Posted by J_Bone
Yeah, I agree with you. They describe it as a cheap conversion. $78-$85 is not a cheap conversion if you go all Avid. That's just to change springs.
Originally Posted by samuelsonmark71
Let me see, 4$ for TLR lower cups that work great or 20$ for ones that do the same job... hmm
Exactly my thoughts..I waited to do the BB spring conversion till I could go all avid..but I dont think im going to any more..
Pancar dude is offline
Old 06-20-2012 | 05:47 PM
  #287
gamedog1966's Avatar
Originally Posted by MikeFrazer
I am setting up a SC10 and I will be running a Reedy 17.5 with a 75T spur gear and i was thinking about starting with a 25T pinion. The track I use has a 100ft straight away. besides looking at temps what is a good final drive ratio?
if u have a short straight like that, i would just go with a mayb 24 tooth pinion u will have toped out alost after half way down it and you should have plenty of low end to make your jumps. if u wnat a little more top just start tuning with the timing on the endbell
gamedog1966 is offline
Old 06-20-2012 | 05:52 PM
  #288
hey guys made a mistake and blew up my esc.....plugged the bullets in the wrong pol omg man it hurt my feelings well luckily i had a spare esc in my pit bag and it didnt take long to tune it for the race which i had to do a matter of min before the race so i was pissed at first. my truck ran good in the first heat, came bck and made a few adjustments and it ran better in the 2nd heat, made more adjustmenst and when we had a break for the mains i ran it for bout 7 laps and man i can tell i was goin in the right direction with the settings and all. so go to the amain and changed tired because the traction was super high so i went to firm inserted slicks and man oh man i tell ya i was dialed for the main and won. wnt from fustrated from the blown esc to winning the main with a differet brand of esc and got it dialed when it mattered.
Old 06-20-2012 | 05:57 PM
  #289
Default the build
hey im about to styart building one of these factory team sc10. is the streeing still an issue with them. i was reading that they strip if you try to load the spring on some how. and you guy run the saver all the way tight from what i read. is there something im forgetting here or is the rest straight foward. thanks rob
imrob is offline
Old 06-20-2012 | 06:00 PM
  #290
Acill's Avatar
Do yourself a favor and just get the avid steering rack. If you don't want to wait, glue it locked down.
Acill is offline
Old 06-20-2012 | 06:21 PM
  #291
Riv2SC10's Avatar
From: In the Greater Ladysmith, WI metropolitan area
Glue it, and get spare bell cranks, cause they tend to break. Its actually the only thing I've broken on one of these. Of course, you can upgrade to the Avid or equivalent, too.
Riv2SC10 is offline
Old 06-20-2012 | 06:30 PM
  #292
Cloaked's Avatar
I Have heard about this gluing thing.... but I dont know what part to glue.
Cloaked is offline
Old 06-20-2012 | 08:01 PM
  #293
J_Bone's Avatar
I would just tighten it up tight and I've never had a problem with it springing out on me.
J_Bone is offline
Old 06-20-2012 | 08:51 PM
  #294
Agree, just get the Avid steering rack. More direct steering and holds a line better than glueing.
Brian L is offline
Old 06-20-2012 | 09:37 PM
  #295
Just about to pull the trigger on one of these.
Would a Tekin RS Pro with 10.5t motor be a good combo for a indoor clay track?
Ironwolf1974 is offline
Old 06-21-2012 | 06:41 AM
  #296
I just placed the rs in my sc10 and it is running great it is smooth and easy to program. I've had one in the 22 I had and the same result except now I know how a nice runnin esc suppose to fee like and the rs is good with just about any motor that's within it capability , I think but I'm not sure you don't suppose to go biggeer than a 5.5 turn ot 4.5 turn or something like that. And chaces are you will prob not go that bigof that motor anyway
Old 06-21-2012 | 08:16 AM
  #297
Acill's Avatar
Where the two plastic parts come together. The upper part gets threaded from the blue aluminum nut into the lower part. Spring is in the center of it. Just put some CA glue inbetween the two halves and tighten the nut all the way down, order the AVID kit and replace it all when it comes in. I also hear the STRC ones isnt bad, but the Avid looks like a pice of jewlery, I love it.
Acill is offline
Old 06-21-2012 | 08:50 AM
  #298
Definitely do the avid steering crank upgrade, just get a quality metal gear servo. Ran mine last nite for the first time and it performed great, took some pretty had hits with no damage
LeftyAEguy is offline
Old 06-21-2012 | 09:15 AM
  #299
markt311's Avatar
Running red Avid springs will make it a bit stiffer and more receptive to wheel adjustments. I run the yellow in front with red in rear and my oil (Front Losi 40wt.; Rear AE 30wt.) is very close.
Keep trying different combos to see what your track requires. I usually only make adjustments between the two heat, then which ever one I like the most I run in the Main.
So would it be your opinion to run Avid springs with TLR lowers and traxxas uppers? or are TLR springs close enough? I run a T4.1 but this thread seems more racer oriented.
markt311 is offline
Old 06-21-2012 | 09:31 AM
  #300
Hey guys,
I just picked up a 2wd sc10 from a friend for dirt cheap. he bought it a couple years ago as a rtr kit and never ran it. im sure the tires are trash because it has been in his garage. I am looking to run the truck and was wondering what you guys rec for me to be competitive, i was thinking about shocks and chassis, tekin pro, fantom motor, and savox servo. any help is appreciated.
kompressor is offline
