Lab C-02
#76
Hello friends!
I had a pre race weekend trying to find the best set up for My CO2 ( the only in Greece....hihihi) and start using Your set up DS.
The only problem is that the track was very slipery and I will need softer springs than stock. ( I think I must ordere them from Cap )
I tryied to set up the front solid axle and check the letest low grip that Our Friend DS pablished but I am having a problem.
How am I going to use the plastic ship with the axle since it doesn't stay in place? Should I use a glue and glue it to the pinion?
If somebody can help please do...
As for shofter springs I used the Blue Xray ( same length ) but I think I will need something harder..Maybe violet...
Besides trying softer spring I would also try lowering the front roll centre. If the car is only oversteering lower the rear roll centre, if the car just doesn't have any grip at all you could lower the roll centre all around.
With the softer springs you could also soften the damping, with the Capricorn white or red springs I use 450-550 oil with 3 hole pistons.
The Xray blue springs are a good set to use when the traction is low or the track is bumpy.
#77
Hello friends!
#78
The practice was placed at R1 race track at Aspropyrgos!
As for the set up Daan I used the one that You forward Me and the car became more grippy but not enough.
As You say I will lower the rol center and order the red springs.Also I will try 500 or 550 damper oil in addition to 600 that I use now.
What do You think about 6 hole damper pistons Daan?
#79
Does anyone know where I can find a 2mm rear sway bar?????
#81
On the co1 it was Johnny, but on my co2 it come with a 2.3mm
#83
Thanks Johnny I'll make some enquires.
#84
#85
Hello All!.
My C02 has a 2.3mm bar and the thiner I have find is a 2.2 which I allready use.
#86
What country do you live in? If you live in North America, Desoto Racing has all the rear bars in stock including the 2.0mm. www.desotoracing.com
#87
I live in Greece but if You can ship worldwide it's ok.
Who should I contact with?
#88
Thanks gents, found one.
#89
Then contact Rc-netshop , mentioned a little earlier in this tread. He lives in Europe , if you get the parts from america , your package will proberly get taken to pay taxes and so.
#90
Well guys,
The Byron's race is going on and DJ Apolaro is TQ with his C02. Taking TQ for 2 of the 3 round he is looking good for the overall TQ for tomorrow.
I will try to get a photo posted later
