Cupboard Cleanup
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Assorted bits and pieces as below, all items open to offers, anything that fits in a post bag will be $8 dollars Australia wide.
1. Xray Spares $40
Short Suspension Arm-Front lower-c hub X2 302159
High Performance Kevlar drive belt rear 305442
Anti-Roll bar rear 1.5mm 303422
Aluminium Nut for suspension pivot pin 302032
Shock Tower Front For Foam tires graphite 302095
Composite C-Hub Front Block Left 6 Degrees 302288
Composite C-Hub Front Block Right 6 Degrees 2X 302286
Front Body Mount Set 301320
Set of Composite Hubs for Bulkheads 302076
Short Suspension Arm Front Lower C hub 302159
Ackermann Extension Plate (2) 302205
Short Suspension Arm Rear Lower C Hub 303159
Roll Center Aluminum Holder Set (2) 303031
Assortment of other X-ray T1/T2 Parts
AntiRoll bar front 1.5mm 302472
Composite C hub Front Block Left Medium 6 Degrees 302288
T2 Rear Suspension Arm 303161
Composite Upper Holder For Bumper 301217
2.Spektrum Telemetry Kit $40
Battery and or Nitro Motor Temperature Sensor
Battery Voltage
Speed Sensor
3. Max Power Pipe and Header Slightly Use, small scratches on the bottom $20
4.Kyosho HangOn Bike Parts (Rider and Body Panels) $40
1. Xray Spares $40
Battery Voltage
Speed Sensor
There's 4 of each of these
Clod stuff is pending - I'll let you know
Focus body pending
XRAY stuff pending
Focus body available again
telemetry kit still available
pipe still available
hang on bike parts still available
blue alloy mini crawler / monster truck wheels and tyres still available
and Xray parts back up
bump
