Mamba Max Pro question? >
Old 05-05-2012 | 02:46 PM
Default Mamba Max Pro question?
I just got my truck put together and noticed my esc is picking up reverse signal but is going forward. Any suggestions on what to do, not much experience with these. Pretty much esc is red when forward on transmitter, and green on reverse on transmitter. Any help would be awesome!
GamerKid is offline
Old 05-05-2012 | 03:17 PM
GLwagon's Avatar
What motor are you using, Sensored or Sensorless?
So when you pull the trigger the red light comes on?
Sounds like the system was calibrated wrong, & servo reversing on the "TH" channel or "Channel 2" should be in the "Normal" position.
If that doesn't work reverse the ch2 & recalibrate.
Give that a try...
GLwagon is offline
Old 05-05-2012 | 04:19 PM
Running the castle 1410, ended up reversing the throttle on transmitter and reversing motor, that seemed to do the job for now. I will try you suggestion and get back to you. Thanks!
GamerKid is offline
Old 05-05-2012 | 06:00 PM
GLwagon's Avatar
Yes Green should be forward... The 1410 is a great motor. If that goes the wrong way just reverse a wire (as you figured out).
GLwagon is offline
Old 05-05-2012 | 09:32 PM
Reversing a motor wire will not change the ESC setup
Need to reverse the throttle channel on the radio to get the setup to recognize the correct throotle / brake signals
Cheers
crusey_aus is offline
Old 05-10-2012 | 03:11 PM
Rockthecatbox21's Avatar
Cheers
I know the motor wires don't effect the esc setup, it just seems that every time i get a new motor i have to switch the motor wires around to get it to work like it should. Even though the castle esc wires and motor wires are color-coded it just seems like i end up having to switch some wires around to get it to work properly. Is there any way to know which motor wire goes to which esc wire?
Rockthecatbox21 is offline
Old 05-10-2012 | 03:27 PM
Order of the wires does not make any difference when running a sensorless motor
If it spins the wrong way simply swapping any two wires will reverse the rotation (or changing the motor direction within the ESC software)
If the ESC calibration is not recognizing the correct throttle / brake signal the throttle channel needs to be reversed on the radio
Cheers
