RC10B4.1 FT/WC
Old 05-05-2012 | 07:25 AM
  #14296
EvanAZ's Avatar
Default donation build
Anyone have a set of RTR shocks and turnbuckles/ball studs for our donation build. Also need a layshaft and thumb screw for battery hold down.
http://www.rctech.net/forum/arizona-...ion-build.html
I'd be willing to give some cash but not a lot.
Trying to finish for the Grand Opening of our track, it will be used as a loaner for our kids RC Program.
Vince
EvanAZ is offline
Old 05-05-2012 | 07:35 AM
  #14297
azwheelman's Avatar
So whats a good starting point for gearing a 13.5 novak ballistic motor for indoor track use ?? A friend suggested 30/ 72 seems a little high ..ive only ran mod motors before with this car lol!
azwheelman is offline
Old 05-05-2012 | 08:14 AM
  #14298
Matt Trimmings's Avatar
I would start around a 28/72 and go from there, i was at about 30/72 with the reedy motor and i know that the novaks like to be geared higher than most anything else out there.
Matt Trimmings is offline
Old 05-05-2012 | 09:57 AM
  #14299
azwheelman's Avatar
Will do thanks ....wasnt to far off lol!!
Old 05-05-2012 | 01:44 PM
  #14300
Andy Davis's Avatar
Building my worlds kit, I got a couple shorty lipos to run in this car. Just curious about a good starting point for the battery placement I bought an extra big spacer foam to cut up, was thinking just starting it dead center in the battery slot. Any advice? Also this will be my stock buggy.
Andy Davis is offline
Old 05-05-2012 | 01:46 PM
  #14301
20 SMOKE's Avatar
i have been running mine in the middle,so far i like it
20 SMOKE is offline
Old 05-05-2012 | 01:47 PM
  #14302
Andy Davis's Avatar
That was quick, Thanks!
Old 05-05-2012 | 02:30 PM
  #14303
Chad Smith's Avatar
Hey guys quick question regarding Regular Lipo VS Shorty. What are the differences you noticed when switching from the Regular Lipo to the Shorty? Was there anything you didnt like about the short battery? I had a 22 and have a couple short batterys left and was wondering what the differences where.
Thanks in advance!
Chad Smith is offline
Old 05-05-2012 | 03:24 PM
  #14304
mxracer458's Avatar
Thanks in advance!
car is way more nimble,jumps and lands 100 times better,you won't wanna run a full size ever again in this buggy
mxracer458 is offline
Old 05-05-2012 | 04:08 PM
  #14305
Thanks in advance!
I was told on higher bite tracks, stick with full size or wolf pack, but low bite packs use the shorty to reduce the pendulum effect. Never did get to try it.
Bob Barry is offline
Old 05-05-2012 | 04:14 PM
  #14306
The Avid BB springs work great, I did go up on my oil by 2.5 weight over the stock springs
Rhett McNair is online now
Old 05-05-2012 | 04:27 PM
  #14307
JEFFs SC10's Avatar
Do you still bottom out with them? I was chassis slapping with 32.5 f/27.5 r granted the jumps were on the bigger side.
I'm not that good enough to be able to downside consistently.
fun driving it, the +8 really made it a lot easier to drive.
JEFFs SC10 is offline
Old 05-05-2012 | 04:32 PM
  #14308
20 SMOKE's Avatar
that is the trick to down side,you can use a tad bit of pack to help
20 SMOKE is offline
Old 05-05-2012 | 04:56 PM
  #14309
I copied some of the local pros and use the shorty with a 1/2 pad up front, and a cut down SC10 pad in the rear. Some guys put a 1/4oz of weight in front of the receiver and that's it. Oh ya and the ballast weight in the rear. That's all no other weight. My car is very balanced and jumps perfectly. I use Losi BB springs. Red front, white rear. Best set up I have had yet. I really like the way it handles. Very controlled. I run a 13.5, and the track is either SRS or Glitch in AZ. All I do is change springs and tires to accommodate each track.
zipperfoot is offline
  #14310
idrummerboy13's Avatar
I'm going to have to try, on the layout change a month ago i only ran a full pack and it seems fine... i did run a shorty on the last layout but that was much bigger jumps and a faster track, this has many more small and tight jumps and fast tight turns...also the key on a set is to square up as best you can on them on they will throw you car straight up just because of the way they are built..
I drove a buddies car and with a shorty pack it felt very fast, and had a lot of steering but was hard to square up on the jumps...
idrummerboy13 is offline
