RC10T4.1 Thread.
Old 04-20-2012 | 06:23 AM
  #1171
Cain's Avatar
Originally Posted by GrimReminder
I just recently bought a AE RC10T4.1 RTR Brushless. Overall I'm pleased as I owned the RC10T back in the 90's which is one of the reason's I picked up this RTR. I'm not really into racing, I like speed and handling. So my question to you guys is. I want speed (45mph to 60mph) and reliability. So what ESC/Motor Combo would you reccommend to achieve this? I would prefer to achieve this with 2s because I feel 3s would be to much. Mind you my brushless setup experience is below novice at best. Basically I want to rip up and down the street or parking with the ability to tone it done for some dirt track bashing. Thanks for your help!
I would use this gearing chart:
http://scriptasylum.com/rc_speed/_top_speed.html
Then from there I would settle on a setup. Personally, when you are looking for the speeds you are, it may be hard to get one motor to do all that as track speeds will be quite different that all out drag runs.
For ESCs, and I am really liking the Speed Passion GT2.0 Pro right now. Strong enough that it can handle SCT 4x4 without a BEC yet reasonably sized. Good price right now too at $107 I believe.
They also got a good sale going on with there V3.0 motors, $60 for a new motor.
Cain is offline
Old 04-20-2012 | 09:08 AM
  #1172
aeRayls's Avatar
Originally Posted by ovalracer1m
The white pads are the rtr basic pads and work ok but glaze over rather quickly and are rather inconsistent. (I personally dont care for them).
The yellow pads are the optional higher friction pads and i feel these work much better. Much more consistent feeling and do not glaze over as fast. These come in the FT kits. They also have a HT yellow pad that has a larger friction surface also.
There's been 3 different pad materials over the years for the b4/t4. They've all been the same part number, just running changes/updates to the material. First there was yellow then white now this gold-ish/yellow we have now.
aeRayls is offline
Old 04-20-2012 | 09:11 AM
  #1173
aeRayls's Avatar
Originally Posted by markt311
I just did this conversion a month or so ago, I got the parts off Ebay and spent $40 before tires and body. Right at $100 total
T4 front body mount around $2
B4/T4 front bumper $2
B4 wing mount/T4 rear body mount $3
T4 chassis around $20-25
T4 battery brace $6 unless you get the carbon fiber one, then $15
T4 front wheel $6
T4 rear wheel $6
and a body $22
I think it's worth it, stadium truck is much more fun for me than short course was.
Also add T4 front axles to the list. They are wider. The SC10 shares front axles with the B4 which are narrower.
aeRayls is offline
Old 04-20-2012 | 09:36 AM
  #1174
markt311's Avatar
Then I have the wrong front axles on my truck lol! I got the hd axles cause I like the no slop fit. Guess I'll have to pick up the proper T4 axles. Thanks for the info
markt311 is offline
Old 04-20-2012 | 10:45 AM
  #1175
brent701's Avatar
never mind. I read that wrong
That's correct. I didn't even think about that.,
I converted my SC10 RS to a T4.1 and had to buy new axles cause RS's has Hex....
brent701 is offline
Old 04-20-2012 | 11:21 AM
  #1176
Ralph289's Avatar
Default Ball Diff Problems :(
Hope someone can help me I am on my THIRD diff rebuild in 2 weeks, what am I doing wrong ????
I have followed the very well written Thread on this site on setting up the diff but I am just having NO LUCK .
The diff is butter smooth after I install it but I can just drive it around in circles in the living room and already it sounds "gritty", and after a day out sounds real gritty. I super CLEAN everything when doing the rebuild but I am stumped. I know not to tighten down the adjustment and flat spot the balls in fact on the last rebuild I left it just a slight bit loose hoping not to damage the balls or rings.
These are the parts I am using am I using POOR parts, any ideas ???
TA Black Grease #6588 for the small rings and balls.
MIP # 9131 Rebuild kit
MIP # 1006 Carbide Ball Diff Lube (I don't believe I am using Carbide balls but MIP say this lube is good for all diffs)
Any ideas ???
THANKS
Ralph289 is offline
Old 04-20-2012 | 12:40 PM
  #1177
aeRayls's Avatar
Uuuummmmm.... Can you please re-read my post.
I said AXLES not A ARMS
I'm not a source of misinformation like 50% of people on here.
Originally Posted by brent701
Incorrect
SC10 T4 share same A-Arms front and rear also share the same rear dog bones or CVA's
Part numbers per Manuals
T4.1 Front Arms #7446
T4.1 Rear Arms #7448
SC10 Front Arms #7446
SC10 Rear arms #7448
The B4.1 Front arms are #9578
The B4.1 Rear arms are #9582
The main thing from the T4 to SC10 is the Chassis. and the front body posts along with rear posts and different wheels/tires.
aeRayls is offline
Old 04-20-2012 | 02:03 PM
  #1178
bds81175's Avatar
Moderator
Any ideas ???
THANKS
There are two ways you can damage the diff right out of the shoot: overtightening or undertightening. If the diff chatters under acceleration that is a BAD thing. It will lay waste to the thrust washers and diff washers in a heart beat. That will be from the diff being too loose and the slipper too tight. Wish I could watch you rebuild the thing in person. Got anyone around you that would be willing to watch over your shoulder while you rebuild it? The thrust assembly is a big part of the grittiness. Don't neglect the thrust assembly when working on the diff. Hope this helps.
bds81175 is offline
Old 04-20-2012 | 02:14 PM
  #1179
brent701's Avatar
Yes I read it again and changes it. it was my bad. No need to try to attack... it was a mistake. (not knowing if you are throwing that 50% BS at me or not)
brent701 is offline
Old 04-20-2012 | 02:44 PM
  #1180
nismomike's Avatar
I was getting a lot of questions about diff building and rebuilding, sanding diff/thrust rings. Setting the diff and slipper. So I posted a thread with pictures in RC Short Course forums that will walk people through it and help.
http://www.rcshortcourse.com/forum/t...fect-diff.html
I realize RC Tech has a simular thread, but sometimes more options can be helpfull.
nismomike is offline
Old 04-20-2012 | 03:38 PM
  #1181
aeRayls's Avatar
No it wasn't at you. I just get tired of reading tons of bad or false advice on here. I don't post often but when I do... it's right.
aeRayls is offline
Old 04-20-2012 | 07:34 PM
  #1182
Originally Posted by princie77
Great suggestion on filling to the same point, I wouldn't have thought of that. I'll be rebuilding this weekend and will post the results. Thanks for the reply.
Just finished the rebuild with filling the diff to the crossbars and it worked perfectly. I used Losi 3000ct diff oil for this one, but I think I'll go to 5000 on the next. Thanks for the help with this.
princie77 is offline
Old 04-20-2012 | 09:13 PM
  #1183
The Czechexican's Avatar
Thay need to come out with a T44.1. I would be all over that!! 4X4 ST
The Czechexican is offline
Old 04-20-2012 | 09:49 PM
  #1184
azwheelman's Avatar
I like that ideal maybe based off the sc10 4+4 or b44 lol!
azwheelman is offline
Old 04-21-2012 | 02:08 AM
  #1185
sapperguy2000's Avatar
cant seem to find it anywhere,, what other than the shocks are different from the T4 and T4.1?
thank you in advance
sapperguy2000 is offline
