TAMIYA M-06 Thread >
TAMIYA M-06 Thread
Like Tree121Likes
TAMIYA M-06 Thread
Old 04-17-2012 | 09:48 PM
  #811
Madulla's Avatar
The carbon tower is needed when using the aluminum upright. 3racing, yeah racing, broad tech, Tamiya all make sets. Get what ever one your rules allow.
The stock plastic will break in the middle between the ball joints if you take a hit to either one of the rear wheels. Almost everyone at my club has broken one. We have mostly M06's run. 20 cars a night.
Madulla is offline
Old 04-17-2012 | 10:04 PM
  #812
snopro31's Avatar
thanks thats very helpfull to know. how do the m06 fair compaired to the m05 aside from the fwd and rwd is there major handling avantages to either?
snopro31 is offline
Old 04-19-2012 | 10:51 AM
  #813
Greetings from Germany!
I found this thread by Google, and i think here are the Experts for the M 06!
My M 06 is a horrible disaster. I was unable to found a working Setup for outdoor Asphalt Tracks.
It goes down as ice, has no traction in the curve and if so then comes the rear around. I've tried a lot, but unfortunately I can not find the right setup.
I have installed the carbon / aluminum shock tower for front and rear. TRF Dampers and springs I use too.
We drive the Tamiya Euro Cup, where we are allowed to drive only the Type A slicks. The drive I use the Carson Brushless Set with 16 turns, Model 500906117. I have built up the chassi in the long version (LWB), because a Mazda RX7 and an old Porsche 911 Body are in my hands.
I've already brought out some tips from this thread, but unfortunately I have not found a setup for my M 06.
Has anyone of you maybe a basic setup, i can work with?
At last, hope you could help me get my M 06 finally runs properly.
BR
Stephan
Freakyduck is offline
Old 04-19-2012 | 02:24 PM
  #814
Raman's Avatar
Freaky duck,
I'm no expert, but I'm very happy with my cars performance. The obvious challenge with this car is to make the rear stable. To achieve this, you have to make the front unstable. I achieved this as follows:
Front: suspension needs to be firm and oil heavy. I run yellow short spring, and 45 wt oil. I also run +1 camber in front with 1 degree toe out. Spacer inside shock is stock from manual.
Back: I run soft suspension, red short spring, 35 wt oil and - 2 camber. Toe in is stock kit. Shock spacer insdie damper is stock rear from manual Rear shock tower, I'm using middle hole. If you're still spinning in turn, you may want to go to 3rd hole, (inside).
I run M-wheel base, with battery in back position. For you I recommend battery all the way back. You want all the weight in back wheels.
Tyres: I run m chassis radial. On front I used hard radial with soft insert. On rear I run S grip radial with soft insert. I don't have much experience with the Tamiya type a slicks.
If you're using brakes before you enter a turn, I recommend you adjust your brake EPA to under 50%. Then test the car, and lower the EPA until it doesn't spin any more.
Hope this helps
Raman is offline
Old 04-19-2012 | 02:27 PM
  #815
Raman's Avatar
Originally Posted by Raman
Tamiya is releasing new carbon front and rear towers for the trf dampers.. (54361 & 54362) The original carbon towers don't work with the TRF dampers?
So no one has news on why they're releasing a second version of front and rear carbon towers?
Raman is offline
Old 04-19-2012 | 02:28 PM
  #816
Raman's Avatar
Freaky duck,
I forgot about diff. Make sure you're oil is not too heavy.. Tight diff will make you spin out
Raman is offline
Old 05-08-2012 | 08:34 PM
  #817
Anyone have a good basic setup to be used on carpet 17.5 thats used with tcs legal tires/parts?
MDRTales is offline
Old 05-09-2012 | 02:25 PM
  #818
I have a lightly used M06 Pro with even less used TRF shocks for sale if anyone is interested. Here's the link
http://www.rctech.net/forum/r-c-item...rf-shocks.html
glinx111 is offline
Old 05-15-2012 | 06:40 PM
  #819
hello all i found this thread looking for m-06 setup tips.
i've been racing and run r/c touring cars for years first was a ta01 and my latest 4wd is ta06 isf.
but this little m-06 has got me for a loop. i can't get it to work right! no matter what i do it will not get any good traction, i just spin out when i get on the power. this not a race car but i would like to be able to have fun with it you know.
ok for the info. i run on streets , the basket ball court and when we run me and my buddys race on a tennis court. the street not getting traction i get because its dirty not prepped or that stuff. the tennis court ? thats like sand paper same with the basket ball court . i just want so help to get the car to handle and run well.
setup now .
front trf shock one hole pistons 40w a/e shock oil stock camber 1. deg toe out tires hpi m compound tires and 0mm offset cup racer wheels . red springs. one rubber o ring under piston. front silver sway bar .
rear. trf shocks three hole piston 32w a/e shock oil stock camber . im running tb01 rear uprights broke stock ones (nasty crash) 1.deg toe on them i think? blue springs rear silver sway bars hpi s compound slicks cup racer wheels 1mm offset.
4000 20c 2s lipo . dyamite fuze 3800kv motor . 16t pinion on motor . gear diff tamiya gease. what i got hope thats enough details. thanx guys and sorry about bad spelling and typing
cosworth34677 is offline
Old 05-15-2012 | 07:55 PM
  #820
Raman's Avatar
Read my post 814, half a page up.
Raman is offline
Old 05-16-2012 | 02:33 PM
  #821
thanx man. will try out the setting once it stops raining
Old 05-17-2012 | 02:04 AM
  #822
alana07's Avatar
does anyone know if the HPI Cup Racer AE86 shell fits M06 chassis?
alana07 is offline
Old 05-17-2012 | 01:27 PM
  #823
Raman's Avatar
Yes
Raman is offline
Old 05-17-2012 | 07:21 PM
  #824
alana07's Avatar
Thumbs up
Yes
thanks....
alana07 is offline
Old 05-20-2012 | 12:29 PM
  #825
mutley001's Avatar
Default What tyres......
Hi all
Just wanted to see what rubber tyres people are finding fastest on carpet?60d or 55d? Not restricted to tamiya but after longevity as well.
Cheers in advance
Paul
mutley001 is offline
