RC10B4.1 FT/WC
Old 03-14-2012 | 01:45 PM
  #12766
Teufel Racing's Avatar
The .5 is .5 per side,
So a 2.5 toe block with .5 hubs will net you 3 degrees of toe per side, though many are opting to run a 3 toe block and 0 hubs.
Teufel Racing is offline
Old 03-14-2012 | 03:59 PM
  #12767
DaveW's Avatar
Sup James?
Im runnin 2.5 toe block and 0 degree hubs on buggy and truck... 2 degree anti squat.
DaveW is offline
Old 03-14-2012 | 04:13 PM
  #12768
bilster44's Avatar
Copied Cavo's battery hold down method here...also decided to drill a hole for balancing so I'd be able to keep the battery in the car a little more often, when there are plenty of heats to do so.
Attached Thumbnails RC10B4.1 FT/WC-photo-2-3-.jpg
bilster44 is offline
Old 03-14-2012 | 05:04 PM
  #12769
Waflet's Avatar
Originally Posted by ray_munday
If you want exit steering, also consider:
- moving weight forward a little (big change, make sure you dont lose too much forward traction elsewhere)
- raise rear roll centre
Ray
hideeho
just to make sure I under stand...
to raise rear roll center i move the camber link in on the hub &/or remove shims/shave down (lower the ball) on the buggy side.
correct?
which is better/should i try 1st?
Waflet is offline
Old 03-14-2012 | 05:14 PM
  #12770
ray_munday's Avatar
Originally Posted by Waflet
hideeho
correct?
Its easiest to take out a washer from the inboard end.
Moving weight forward will have the biggest effect.
Ray
ray_munday is offline
Old 03-14-2012 | 05:39 PM
  #12771
darryl80's Avatar
how well of a basher would a b4.1 be because i bought 1 for dirt cheap.
darryl80 is offline
Old 03-14-2012 | 06:16 PM
  #12772
flippz's Avatar
Originally Posted by mxracer458
did you mean 1/2 degree?
yeah, sorry, 1/2 not 1/5
flippz is offline
Old 03-15-2012 | 04:46 AM
  #12773
bds81175's Avatar
Moderator
I suppose any car you managed to get a great deal on could be a good basher. I don't know jack about bashing. The B4 was designed to be a race car. If you pack the outdrives with mud and get dirt inside the transmission its not going to run very well.
bds81175 is offline
Old 03-15-2012 | 05:41 AM
  #12774
Default Loctite and upgrades?
I'll be assembling my b4.1 later(I've been out of rc for 10 years) and wanted to know if I should use loctite on anything? And also if I should upgrade anything on the buggy right off the bat?
InfamousJon is offline
Old 03-15-2012 | 06:35 AM
  #12775
ray_munday's Avatar
loctite: on the 4 screws which pass through the transmission into the motor plate, and on the 4 shock upper mounts (alloy). No need anywhere else as its all into plastic.
No need to upgrade anything from the WC kit... except for the rod ends. If you are starting out with wheels etc you may want to consider changing to the hex rims (personal preference only).
Ray
Old 03-15-2012 | 07:04 AM
  #12776
Awesome thanks.
Does the kit include loctite? I got to the front shock tower and it says to use loctite and gives a part number, but I can't seem to find it and I'd rather not open every bag in advance. If I can't find it what color is recommended?
One last thing(for now) : I didn't see a "Box 1" anywhere and it wasn't checked off on the little packing slip, is that normal? The slip was signed, but again, the "box 1" wasn't checked.
Thanks!
Ray
Old 03-15-2012 | 07:22 AM
  #12777
racer1812's Avatar
Super Moderator
Loctite is NOT included, use blue.
racer1812 is offline
Old 03-15-2012 | 02:25 PM
  #12778
Slashed Income's Avatar
Default AKA Vektor
Is anyone running AKA Vektor fronts? If so, which way do you have them mounted and for what type of surface?
Slashed Income is offline
Old 03-15-2012 | 02:58 PM
  #12779
idrummerboy13's Avatar
i tried em when the surface was wet, i like the feel when the tip of the arrow was pointing away, less steering.
Clay wet to dry medium bite. Rears were concept golds. They were hooked
idrummerboy13 is offline
Old 03-15-2012 | 03:01 PM
  #12780
T-BirdJunkie's Avatar
The "V" facing forward on clay. The supersofts are dialed...Scrubs are good too. What kinda surface are you on?
T-BirdJunkie is offline
