RC8Be to RC8.2e Conversion Parts List (Complete))
#16
ok awesome, thanx for the reply.
What I would do is just go with his list and actually go to a website like www.towerhobbies.com or www.amainhobbies.com and price everything out and that should give you a pretty good estimation of what you would want to do from there. If you have the money now, and wanna spend it, I would just buy the RC8.2e and you will not be disappointed.
#18
I don't have an RC8, I have a Ve8. I have been looking at the RC8 though, this list was definitely helpful. I am sure many others want to know what the differences are. Thanks for putting in the time and effort to list all the differences!
#19
! Im glad that this list has helped you out, and I hope it does for many others in the future.
#20
So I went a head and added everything up on the list. I crossed referenced both cars and noticed some items you don’t really need, they either look cooler or are the exact same part (89380 blue anodized aluminum steering blocks) these come with the 2e kit but are exactly the same as the ones on the be kit except they aren’t plastic. I don’t know if I miss typed anything but I got a grand total of $710... So yeah, incase any of you are wondering, just buy the new kit.
#21
I have a Tekno V4 RC8 conversion. I was checking on updating just the suspension to 8.2 spec and well...
I was at 373.18
. That was with shocks, springs, towers, A,B,C, and, D plates, upper and lower arms, caster blocks, sway bars, wing mount and wing.
Ill just go but the whole buggy for less than $100 more and sell the one I got!
Parts I had added:
ASC89540 - Team Associated Wing Mount (RC8.2)
ASC89304 - Team Associated "Illuzion" 1/8th Scale Wing (Black)
ASC89551 - Team Associated Rear Arm Set (RC8.2)
ASC89550 - Team Associated Front Arm Set (RC8.2)
ASC89549 - Team Associated Front Upper Arm Set (RC8.2)
ASC89530 - Team Associated Front Swaybar Kit (RC8.2)
ASC89531 - Team Associated Rear Swaybar Kit (RC8.2)
ASC89558 - Team Associated Caster Block Set (RC8.2)
ASC89539 - Team Associated Aluminum Rear Shock Tower (RC8.2)
ASC89538 - Team Associated Aluminum Front Shock Tower (RC8.2)
ASC89541 - Team Associated Front Shock Spring Kit (6) (RC8.2)
ASC89545 - Team Associated Rear Shock Spring Kit (RC8.2)
ASC89290 - Team Associated Factory Team 29mm Big Bore Front Shock Kit
ASC89346 - Team Associated Factory Team 38mm Big Bore Rear Shock Kit
ASC89460 - Team Associated Suspension A-plate
ASC89481 - Team Associated "Low B" Suspension Plate w/Inserts
ASC89462 - Team Associated Suspension C-plate
ASC89463 - Team Associated Suspension D-plate w/Pins
I was at 373.18
. That was with shocks, springs, towers, A,B,C, and, D plates, upper and lower arms, caster blocks, sway bars, wing mount and wing.Ill just go but the whole buggy for less than $100 more and sell the one I got!
Parts I had added:
#22
#24
Yes, the 8.2 chassis is 3mm longer.
I'm actually one of dumb ones who has replaced each part instead of building a new kit. The only thing I haven't changed yet are the lightened ring gears & the front lightened diff outdrives & the motor mount. I ran mine yesterday @ SDRC, car ran great, had awesome steering & it was stable but I didn't have a good set up on it, but I still finished 2nd
Thanks for the conversion list!
.Thanks for the conversion list!
#25
Just bought and RC8Be and began doing some of the conversions. I did the A Arms front and rear. Sway Bars Front and rear. Had to grind down a couple of areas in the front a arms to get them to work properly. Is there any other parts that are absolutely a must have on this list? Chassis? and those parts? Thanks for the list and the advice!
#26
My car is a rc8be with the worlds upgrades. I priced out the rest of the suspension parts and the wing mount on Amain and my list was near $250. I decided I will just run the car as it is now and mid season I will do more of the conversion as my car is ready for a rebuild. I figure the lightened drivetrain parts arent a big deal to have since my buggy already seems overpowered and the extra couple millimeters of the shock towers and shock length might even work to my advantage since the ebuggy is so heavy. I figure having the long chassis and new geometry ought to be enough to get by for a while.
#27
It's about 1/2 the price if you get the parts on eBay..just have to be smart about what you buy and from who your buying it from..I "might" do this by just doing the Chassis, A arms & shock towers..I just went through all my diffs and installed a new bearing kit, I do plan on getting a new RC8.2e but my converted 8e would make a great practice buggy..in fact I'm thinking about trying the longer chassis & rear center shaft to start off with, just adding the longer chassis would make an improvement on a rough track..
#29
You can get a new kit in th box from team associated for $275 on their web specials. The kit doesn't have an problems. The newer 8.2 is just a little longer & has a different suspension set up.
#30
The older RC8 is not bad and it's still more than capable of winning..but the the newest version.. the RC8.2e is waaaaaay better on a blown out track, is a lot smoother, jumps better.. It's a much improved product, personally I would wait a while, save your money and get the 8.2e..
