View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Selling Futaba Receivers Rx
Futaba 152JE and 142JE 2-channel Micro Receiver 27mhz AM Mint Condition
-Antennas never been cut or replaced
-Bought new from Lil's for 2000 pesos each
-Will work with HPI, Tamiya, HOBAO,as they are also made by Futaba
-Perfect for most Crawler RC due to small size also have matching 3 RX Crystals 26.995 and 1 TX Crystal 26.995
-price to sell at 800 pesos each 3 available
If interested please contact me at 0927-996-9175 thanks Alexander
Drift parts:
SPRINGS - orange (stock TT01D) silver (stock ER) - 250/set of 4
BELT - 77T di ko alam brand - 300
(see attached pics)
Heli 450 spare parts
repriced some items
1 - CNC Head and Tail set - part out text for individual price.
3 - Aluminum tail servo post - 150
4 - 2 sets tail blade (yellow) - P200
5 - 2 pcs metal gear micro servo - P500
6 - Hobbyking HK401B head loack gyro - P450
7 - 450 frame - P700
8 - (bnew) align tail boom - P150
9 - (bnew) CF main blades - P500
KDS K-7X tx with KDS K-8X receiver - P2300
My other stuff
FOR SALE
text
09228134388
(see attached pics)
repriced some items
My other stuff
FOR SALE
text
09228134388
For Sale IMAX B6 Brand New
- Php1,800.00 w/o 12v 5A Adaptor
- Php2,300.00 w/ 12v 5A Adaptor
(Reference Pic only)
Personalized RC Bag (12" x 8.5" x 29")
Made from Poly Canvass Material
Made to Order (Lead Time 3-7days)
Php2,000.00
Meet up in any MRT/LRT Station
Imax B6AC Brand New
Php 2,800.00
Reference Pic only
All prices are fixed
Meet up COD (any MRT/LRT Station)
Pick up Bocaue Tollgate (NLEX)
We shipped thru LBC
09224790923
Php2,000.00
Imax B6AC Brand New
Php 2,800.00
Reference Pic only
We shipped thru LBC
09224790923
FOR SALE. FIRM PRICES, PICK UP ONLY FOR
NOW. TO AVOID BEING INCONVENIENCED
KINDLY READ ALL THOROUGHLY, THANK YOU.
1.0) B/N 6804 PLATINUM EDITION SLASH 4X4 ARR.--------------------P19,450 ONLY.
>FREE BONUS ITEM OF B/N HK-GT2
3CH 2.4 GHZ RECEIVER W/BIND PLUG.
2.0) NIB 1/18 RTR BRUSHLESS XTM RAGE TRUCK.----------------------P7,480 ONLY.
>FREE BONUS ITEM OF B/N HK-GT2 3CH
LINK BELOW IS FOR REFERENCE ONLY.-
http://www.hobbypeople.net/index.php...y-charger.html
3.0) B/N HK-GT2 2.4 GHZ SYSTEM W/2 PCS. RX.-----------------------P1,950 ONLY.
>SAME AS FLY SKY FS-GT2.
4.0) <10 TIMES USED HPI GT 550 MOTOR 14.4V.-----------------------P550 ONLY.
http://www3.towerhobbies.com/cgi-bin...?&I=LXPCU6&P=Z
5.0) B/N HARDCASE TURNIGY 5000MAH 2S 40C LIPO.-------------------P1,980 ONLY.
>FRESH, 40-50C, 5.5MM BULLET CONNECTORS,
MANUFACTURER'S DIMENSIONS GIVEN AS
139 X 46 X 26 MM. 200 AMPS CONTINUOUS.
FREE DEANS TYPE FEMALE PLUG.
6.0) B/N NOVAK .8 & 1 MOD 5MM BORE PINIONS.-----------------------P650 ONLY.
>16T & 17T ONLY.
7.0) B/N CC .8 MOD 18T 5MM BORE ALLOY PINION.---------------------P320 ONLY.
ABOVE ITEMS ARE FOR PICK UP AT MY WORKPLACE 10A.M.-4P.M.
WORK WEEKDAYS AT THE EDSA-GREENHILLS AREA. SATURDAYS
9A.M.-10A.M. BY SPECIAL ARRANGEMENT ONLY.
FOR QUESTIONS KINDLY PM ONLY.
FOR THE DIRECT PURCHASE OF THE ITEM KINDLY TEXT OR CALL
DON AT +63915-4524488. INCLUDE YOUR FULL NAME AND RCTECH.
NET USERNAME WHEN TEXTING. THANK YOU RCTECH.NET,
MODERATORS & TO ALL FOR BROWSING.
>16T & 17T ONLY.
For sale:
TTO1E ready to run
Full bearings,remote, reciver, motor,esc,venom nicd battery,futaba servo,lrp charger,te37 rims and drift tires,protoform stratus body, 8pcs AA---- 5k only
TRF415 MRE
Full carbon fiber,TRF shocks,aluminum hex,sorex tires on yokomo wheels medium insert,protoform body silver can motor, will also include a spare lower and upper carbon fiber chassis. ---- 9k
Traxxas emaxx (3905 brushless ready) ready to run
Water proof esc and servo,upgraded 8pcs aluminum blue shocks,aluminum shock tower rear,rpm bumper, ford f-250 body,traxxas tx and rx---- 12k
Losi 350 nitro engine .21
With flywheel,clutch assembly and clutch bell----3k
(red) Alpha plus pro spec nitro engine .21
Engine only no flywheel----3k
Futaba bls 352 servo----3k
more items to follow soon...
Items are in nueva ecija
Call me for any question on the items 0922-936-5091 tnx
TTO1E ready to run
TRF415 MRE
Selling my kyosho spider mk2 almost new test run only 2 times
Includes:
Kyosho spider mk2 kit with the original engine
1 acme servo throtle
1/4 gallon rapicon 25% nitro fuel
Igniter with charger HSP
Bashed 200 mm HPI toyota weld shell
Some spares
All in for only 5.5k pwede din swap (swapping value 6.5k)
Tx me for faster transaction 09178381651
I can send pix thru email
Meet ups Pasig,Makati,Mandaluyong, D fort Taguig areas
Thanks RCTECH
Includes:
Some spares
Thanks RCTECH
Serpent 811 only used in a big race selling it for 15k w/ fr alu shock tower and front & rear alu brace and option2 steering rack
Call or txt 09174667222
Sir check out nyo sa YouTube "RC Nitro Setup Guide Part 1" by Squirrelod it might help or use the instructional manual inside the box. Where's the pic sir dumating na ba?
Good luck and have fun sa pag setup!
Used RC gas boat parts
Attachment 889596
Attachment 889597
Attachment 889599
Used aluminum tuned pipe for rc gas boat w/ watercooled flanged and header
P2,500 only
Used walbro 257 carb for rc gas boat P1,500 only
Stock butterfly carb for rc gas boat P500 only
Brandnew Items:
The KD36 inrunners are equivilent to 540 size motors. P2,000.00 only
Front mount holes are 25mm apart.
Dimensions: 36~60mm
Shaft size: 5mm
Weight: 260g
Spec.
Kv: 2700rpm/V
Idle Current: 3.4A
Resistance: .0097
The new Turnigy Lipoly packs deliver full capacity at the said C rate.
You wont find a better deal in Lithium Polymer batteries anywhere!
P1,200 only
Spec.
Minimum Capacity: 2200mAh
Configuration: 3S1P / 11.1v / 3Cell
Constant Discharge: 30C
Peak Discharge (10sec): 40C
Pack Weight: 207g
Pack Size: 117 x 34 x 24mm
Charge Plug: JST-XH
Discharge Plug: XT60
Turnigy 12v Electric Fuel Pump/ reversable P,1000 only
Suits Nitro and Gasoline
Specs.
Input: 12v or 3s lipo
Size: 90mm x 49 x 37mm
Nylon T-connectors.P450 per pack (10pairs)
Pack includes 10 male and 10 female connectors.
ALERT!
These connectors are made from Nylon, making them very tough and difficult to melt, even with the worst of soldering skills.
P500 per pack (10 sets)
This is a great way to avoid power shorts.
Rated to around 93A
Gold connectors on their own are notorious for creating a short circuit and looking messy. Use these to keep your connections safe and looking neat!
An excellent replacement for Deans T-connectors!
Good for wire up to 10AWG thickness.
Easier to solder and a stronger connection than Deans T-plugs
Turnigy 1/4 SIZE S8166M Servo 154g / 33kg -FOR 1/4 & 1/5 SCALE RC CAR, TRUCK AND BOAT
Weight: 154g
Dimensions: 75 x 59 x 27mm
Torque: 33kg-cm
Speed: .21 deg/sec
Bearing: Twin
Gear Type: Metal
WE SHIP THRU LBC AND AIR 21
PAYMENT OPTIONS: LBC, PNB AND BDO (PREFERRED BDO)
FULL PAYMENT BEFORE SHIP OUT
NO RETURN NO EXCHANGE POLICY..WE TEST ITEM/S BEFORE SHIPPING OUT EXCEPT FOR ITEMS THAT ARE SEALED OR BOXED.
OTHER ITEMS AVAILABLE:
RC BOATS, HULL, ZENOAH ENGINE, BRUSHLESS MOTORS, LEOPARD MOTORS, BOAT HARDWARES, ELECTRNICS, ACCESORIES AND ETC.
MEET UPS: QUEZON CITY CIRCLE /COMMONWEALT AVE/SM FAIRVIEW
PM OR CALL 09175197191- BONG
ARRIVING SOON
P3,000 ONLY
Spec.
Capacity: 5600mAh
Voltage: 2S2P / 2S Cell / 7.4V
MAX CHARGE RATE 8C
Discharge: 50C Constant / 100C Burst
Weight:294g (including wire & case)
Dimensions: 138.5x47x25mm
Balance Plug: JST
Discharge Plug: 4mm Bullet-connector to your own custom plug
P1,000 ONLY
Model: TGY-1501MG
Voltage: 4.8~6.0v
Speed: 0.16~0.14sec
Torque: 15.5~17.0kg/cm
Weight: 60g
HI-SPEED SERVO P1,000 only
Corona 538MG Digital Metal Gear Servo 7.0kg/ 58g/ 0.13sec
Model: DS538MG
Operating Voltage: 4.8V / 6.0V
Operating Current: 300mA / 400mA
Operating Speed: 0.14sec.60º/ 0.13sec.60º
Stall Torque: 6.5kg.cm / 7kg.cm
Weight: 53g
Dead Band: ≤3uSec
Operating Travel: 40º/one side pulse traveling 400us
Potentiometer: 5 slider/Indirect Drive
Ball bearing: MR106
Gear: Metal
Connector wire: 215mm
Operating Temperature Range: -20 J to +60J
Turnigy MG958 Composite Digital CORELESS Metal Gear Servo 15kg / 65g / 0.2sec
REPRICED- P1,300 ONLY
TGY-MG958 spec.
Control system: +pulse width control 1520usec neutral
Required pulse: 3-5V peak to peak square wave
Operating voltage: 4.8V
Operating temperature range: -20~+60C
Operating speed: 0.2sec / 60 degree at no load
Stall torque @ 4.8V: 166 oz/in. (12.0kg.cm)
Stall torque @ 6.0V: 200 oz/in. (15.0kg.cm)
Operating angle: 45 deg. one side pulse travelling 400usec
Direction: Counter clockwise/pulse travelling 1520-1900usec
Motor type: Coreless motor
Potentiometer drive: Indirect drive
Bearing type: Dual ball bearing
Gear type: All metal gears
Connector wire length: 12in
Dimensions: 40.2 x 20.1 x 36.8mm
Weight: 2.24oz. (65g)
Attachment 889596
Attachment 889597
Attachment 889599
P2,500 only
Brandnew Items:
Dimensions: 36~60mm
Shaft size: 5mm
Weight: 260g
Spec.
Kv: 2700rpm/V
Idle Current: 3.4A
Resistance: .0097
P1,200 only
Spec.
Pack Weight: 207g
Charge Plug: JST-XH
Specs.
ALERT!
Rated to around 93A
Weight: 154g
Torque: 33kg-cm
Speed: .21 deg/sec
Bearing: Twin
Gear Type: Metal
ARRIVING SOON
P3,000 ONLY
Spec.
Capacity: 5600mAh
MAX CHARGE RATE 8C
Balance Plug: JST
P1,000 ONLY
Model: TGY-1501MG
Voltage: 4.8~6.0v
Speed: 0.16~0.14sec
Weight: 60g
Model: DS538MG
Weight: 53g
Dead Band: ≤3uSec
Ball bearing: MR106
Gear: Metal
TGY-MG958 spec.
1Likes
