TAMIYA M-06 Thread
#797
Do you mean putting spacers on shock piston inside the damper cylinder?
Thats usually done as a substitute for droop screws since these cars do not have droop screws on the suspension arms.
If you look at step 19 and 20 in manual (page 12 / 13) you will notice that you do install V11 spacer in rear and V3 spacer in front
#798
Not sure what you mean by shock limiters for lower CG?
#801
I'm just finishing up my 06 pro, did anyone else have to shorten the upper front camber link? built to the instructions it was way too long.
I got the carbon towers and sway bars to have some tuning options, need a good low grip setup..
#802
#803
Originally Posted by MUDVAYNE View Post
I have done that per the instructions. I'm just wondering if anyone has added a little more? My car seems to lean alot entering the corner.
Sway bars should address that... Im presently running without them myself, looking to give to try them out soon.
Today 01:54 AM
Today 01:54 AM
I also have to reduce roll, as I run the beetle body...
BR,
Matthias
#805
Yeah I figured it was something like that, but the link WAS the same length as the picture, and still would have produced a lot of positive camber, I shortened the turnbuckle and used a shorter cup..
#807
i am building a m06 and m05 for tcs racing, i cant get a pro version as they are out of stock , for the mo6 what are the hop ups i need to make sure i have to be ready to race fully? does anyone have a starting point set up for pavment and or carpet?
#810
for the shocks what tamiya set is the set people found better on the mini?
121Likes
