RC10B4.1 FT/WC
Old 01-21-2012 | 10:00 AM
  #10081
idrummerboy13's Avatar
Most tires need to be scuff in first before racing ...
So to say JC V2 "sucks out of the bag" is far from a fair statement...
you think they will faster the pink bks? And outa the bag bks are faster, and worn down amazing.
wet damp 70%clay 30 topsoil. Very very small amount of dust usually its clean.
Med high bite.
idrummerboy13 is offline
Old 01-21-2012 | 10:03 AM
  #10082
Teambcw's Avatar
Med high bite.
you are very close to my local track conditions, V2 did nothing but make me mad every time I used them. They do work great outdoors though.
Teambcw is offline
Old 01-21-2012 | 10:20 AM
  #10083
Our local indoor track is flipouts and rips... too much loose stuff in spots for barcode type tires and it's not the typical "indoor" clay/dirt. More of an outdoor mix.
I switched from silver/pink springs over to orange/yellow last night. Also running 32.5 / 30 with 2 pistons now. not sure if I am going to stay here or not. The car seemed to bounce around alot with silver/pink. Was better with Orange/Yellow, but still had some bounce to it.
Here's a decent pic of our track on this post
http://www.rctech.net/forum/10204823-post742.html
Bob Barry is offline
Old 01-21-2012 | 11:12 AM
  #10084
Wild Cherry's Avatar
drummerboy
At Trcr ?
Not uncommon to see many using Pink Bk Losi when the track is a fresh rebuild , but just after a few race days ?
JConcepts come on hard everyone switches to the JC ...
I don't think it would fair for me say the Bk "suck" . Just sometimes some tires perform better then others under certain track conditions...
Knowing when to use each type of tire is the key ....
Wild Cherry is offline
Old 01-21-2012 | 11:25 AM
  #10085
B.A. Racer's Avatar
can you use the same method to turn the blue associated turnbuckles gold as the silver titanium ones?
B.A. Racer is offline
  #10086
Just1More's Avatar
I've experimented with cutting the outside ribs on front barcodes off with scissors, seemed like they entered the corner a tiny bit slower but everywhere else the same, but the pair that i cut were using cut rear foams and my regular pair has proline blue closed cell foams, i prefer the closed cell for more steering(I haven't tried cutting the rib and using closed cell though)
Just1More is offline
Old 01-21-2012 | 12:13 PM
  #10087
Does anybody know if I have to buy the strap with the +8mm chassis? Will a T4 strap work?
desertraton is offline
Old 01-21-2012 | 12:24 PM
  #10088
drummerboy
At Trcr ?
Yea ik your right. But i will update when
Scuffed. Trying gold blue greens
Been
Running #1 piston 35 oil 2 limiters front #3 piston 25 oil 2 limiters.
Dk yellow front green
Rear. Great results
Old 01-21-2012 | 12:34 PM
  #10089
oldnfat's Avatar
Originally Posted by dirt_oval
The Shuey rims should fit. The rears for sure. I used my AE front rims on my Cougar when I had it, so I do not see why it cant be vice versa..
Well they came in today, I guess the Shuey use's a drive pin in the front and not bearings in the wheels like the associated. looks like the rears fit ok tho.
should have just bought the tires and glued them up myself, lesson learned.
oldnfat is offline
Old 01-21-2012 | 12:53 PM
  #10090
brian cox's Avatar
the t4 strap will not work..If I remember correctly it's longer in the front of the strap instead of the back
brian cox is offline
Old 01-21-2012 | 01:03 PM
  #10091
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
The +8 conversion comes with the strap.
ASC9636
SpraydbySprague is offline
Old 01-21-2012 | 03:12 PM
  #10092
ViGiLaNtE351's Avatar
When you buy the kit, you will get the chassis, strap and extra foam.
Cheers
ViGiLaNtE351 is offline
Old 01-21-2012 | 03:14 PM
  #10093
YankeeFan123's Avatar
yeah, how do you do that? a couple of the pros at my local track have those, how do you do that?
YankeeFan123 is offline
Old 01-21-2012 | 03:16 PM
  #10094
B.A. Racer's Avatar
http://www.youtube.com/watch?v=wyWtc067nts
but im not sure if you can get the blue ones to come out gold
Old 01-21-2012 | 04:20 PM
  #10095
Hi all. Im seriously considering getting into 10th scale electric to go along with my 8th scale nitro racing. I'm thinking about buying a b4.1 rtr that tower has a 3 easy pay plan just to get my feet wet and I'd hop it up little by little. What I wanted to know is this rtr durable and is the reedy motor that comes with it decent or would I be better off just buying the hoped up version and not waste my time and money? I do plan on racing it but not no where as much as I do my 8th scale nitro to start off with. Any suggestions and advice would be much appreciated and thanks in advance.
rcmoe is offline
